Exceed RC Racing Terrain 1/10 Scale Short Course Truck Ready to Run 2.4ghz (AA Green)
![Default](https://www.rctech.net/forum/images/icons/icon1.gif)
![](https://cimg6.ibsrv.net/gimg/www.rctech.net-vbulletin/700x400/80-51c808_10_desertsct_aagreen_24g_1_0a0cd7ef9dcb35c43ddf8eb792ea963b4358fc57.jpg)
![](https://cimg7.ibsrv.net/gimg/www.rctech.net-vbulletin/700x400/80-51c808_10_desertsct_aagreen_24g_2_110e9b799f69c0df8cd2d6fa3a2d8505c2762130.jpg)
![](https://cimg8.ibsrv.net/gimg/www.rctech.net-vbulletin/700x400/80-51c808_10_desertsct_aagreen_24g_3_13628e95391aab340aaa2b9664a8be5fe23d40c7.jpg)
![](https://cimg9.ibsrv.net/gimg/www.rctech.net-vbulletin/700x400/80-51c808_10_desertsct_aagreen_24g_4_3932c45ae6c5dd9b8c77dcae8646bc552e78c92c.jpg)
https://www.nitrorcx.com/51c808-10-d...green-24g.html
https://www.youtube.com/watch?v=SniVzkTChGQ
You are looking at the newest short course truck derived from the Exceed Racing Factory. This is a complete ready to run short course truck. It includes a brushed waterproof electronic speed controller with proportional forward and reverse function. The electronic speed controller pushes power to a high torque 550 canned brushed motor. The power delivery is enough to spin the tires and perform massive dirt power slides like a scale trophy truck would. Aggressive all terrain tires mated with beefy off road wheels ensure traction and control in a variety of landscape conditions. The Terrain Truck platform consists of a shaft driven? 4 wheel-drive system, geared differentials, aluminum upper deck chassis, aluminum drive shaft, metal axes and oil-filled shock absorbers with progressive springs to tame any terrain. The steering mechanism is handled by a high torque servo allowing aggressive all terrain driving. The entire chassis is enclosed in a durable composite roll cage with scale driver and co-pilot included. Dirt, sand, snow, mud, rain, this truck will smash through it all.
This truck is ready to run. It includes an Exceed RC 2.4ghz radio control system for optimum driver and machine communications. It also included a 7.2v 1800mah Ni-MH battery and charger.
Features:
1. All terrain treaded tires and off-road style wheels
2. Covered spur gear cover
3. Oil-filled shocks
4. Robust plastic shock towers
5. Front and rear metal geared differentials
6. Brushed 550 Motor
7. Li-Po compatible Brushed ESC
8. 4WD shaft drivetrain
9. Adjustable Servo with saver
10. Steel hinge-pins with rounded front bumper
11. Exceed radio system with 2.4GHz technology
12. 7.2V 1800mAh NiMH battery with 3.5mm gilded round connectors
13. 12mm standard wheel hexes
Specifications:
Length : 465mm
Height : 195mm (body excluded)
Width : 255mm
Wheel Diameter : 86mm
Wheel Width : 34mm
Wheel Base : 265mm
Weight : 2120g
Gear Ratio : 8.133 : 1
Ground Clearance: 33mm
Motor: RC550
Servo: 6KG (Waterproof)
Battery: Ni-MH 7.2v 1800mah
Package Contents:
100% Assembled
1x 1:10 Exceed Truck
1x 2.4Hz Transmitter/Receiver
1x Battery Charger (100-240V)
1x 7.2v 1800mAh Ni-MH battery
1x Instruction Manual
Required to Run:
4 AA Batteries for 2.4ghz Transmitter
![NitroRCX.com is offline](https://www.rctech.net/forum/images/statusicon/user_offline.gif)
