Maxy's Cinco BT .21
#151
Finally got to run mine on the track. Broke it in without the restrictor to try and get as much oil through it as possible. Forgot to grab the restrictor before I left the house..oops. I am also waiting on my pipe so I borrowed an alpha pipe from a buddy at the track. Not even sure which one only that it was very loud! Engine has a ton of power and I timed the last run for the heck of it...remember no restrictor at all and unknown pipe and it ran out at 9:30. I'll be honest I am looking forward to adding a restrictor...the motor has a ton of power and that will calm it down some. Good to know there is a ton of power on tap if needed. I cant wait to try the tuned version!
#152
#154
It will be nice to get some of the Maxy Fuel and some of those Cinco BT's up here. I hope you remember me. I may come to Mills Pond during Mid May.
Alan Fundora
#156
Alan I sent private msg
Wow Maxy...you have come a long way since I use to race with you and the other guys in 2007. I moved to Tennessee and helped co-found our track. Www.rocckracing.com. We average about 100 entries on a good day and 60 on a bad day.
Alan Fundora
Alan Fundora
#157
Super happy with my Maxy's CINCO BT!!!! 10 minutes with no problems and has a lot of power! definitely will buy it again!!!
Ernesto Martinez.
Ernesto Martinez.
#158
My buddy ordered a ceramic maxy, did 1000cc prop break in. Put the 41019 short header with 2096 pipe ran it didnt like the avid ceramic they come with, changed out to nova steel bearings went back out, and was getting 11 mins with less than a gallon on it. Very impressive engine, was still running a little hot obviously since it was still tight but none the less 11 minutes per tank. Great engine/pipe/header combo.
#160
With less than a gallon, i can imagine once its loosened up a bit itd be even better.
#161
Since I had posted that I had my Cinco torn apart, I had some request for pictures of the internals. I finally had the opportunity last night to sit down and get some pics with a side by side comparison of an old P5 I have.
I've heard mumblings that the Cinco BT is just a P5 with a different head. I can tell you this is not true. Look at the run times people are getting out of the Cinco BT, that alone should tell you it's not a P5. When was the last time you saw a stock P5 pull 11 or 12 minutes in a buggy? Probably never
In buggy, the P5 is a 8 or 9 minute motor, they aren't known for great run times.
Anyway, here's the pics I took, you can draw your own conclusions. There are some significant similarities and differences as you will see. Keep in mind that my P5 was tuned by HES and my Cinco BT is also the tuned version.
Pistons: P5 on the left Cinco BT on the right. You can clearly see that the Cinco BT uses the Nova Team piston and the P5 doesn't.
Head Buttons: P5 on the right and Cinco BT on the left. Same head buttons, same numbers on them.
Sleeves: P5 on the left and Cinco BT on the right. My P5 was tuned by HES, so that makes it very difficult here for me to determine if the sleeves are the same. Obviously both are 5 ports, but I don't know how much was done by Monty and if Maxy did any port work on the Cinco BT. If I had to guess, I would say the sleeves started life as the same.
Cranks: P5 on the left and Cinco BT on the right. Here is the most significant difference between the 2 engines. The P5 crank was filled with silicon and that's the only thing that was done to it as far as I know. The cranks are clearly different and have different numbers on them as well.
I didn't get pictures of the cases, couldn't get them to come out. I initially thought that they were different, but after inspecting them side by side, they do appear to be the same internally. The only difference is the Cinco BT case is milled at the top to allow for the low COG head.
#162
man the P5 had some dirt in it???
#164
Sleeves: P5 on the right and Cinco BT on the left. My P5 was tuned by HES, so that makes it very difficult here for me to determine if the sleeves are the same. Obviously both are 5 ports, but I don't know how much was done by Monty and if Maxy did any port work on the Cinco BT. If I had to guess, I would say the sleeves started life as the same.
These changing are supposed to do the following and they do imo:
Make the p/s last longer
Give smoother power band
Better Fuel mileage
More RPM's
Remember these engines are very small, so any little change can make a huge difference in performance. Ask anyone who has tried both the old P5 and the Cinco BT and they will tell you the Cinco is way better.
If you want to make a P5 into a Cinco, you can. But you would need to Spend $180+ to buy the CNC piston/sleeve, plus buy a LCG head, and mill down the block so it fits. Why do all that when for $70 more then a P5XLT you can buy a Cinco BT that is ready to go 10+ min on a tank.
#165
here is what I see...a P5 with a Team piston and a slightly raised exhaust port...crank timings are stock......Nice engine really , the Team piston and altered exhaust timing will improve the engine quite a bit over a regular P5....
