Seattle RC Racers/Hangar 30
![Default](https://www.rctech.net/forum/images/icons/icon1.gif)
bu dum tsss!
![Big Grin](https://www.rctech.net/forum/classic_images/smilies/biggrin.gif)
Corner balancing isn't the same as balancing left to right imo. By eliminating the spring you eliminate the variable introduced by the springs. If springs were perfectly equal this wouldn't be an issue. But since each spring is different its best, in theory, to remove them to balance L/R. Once you have a true 50/50 balance left to right you put the shocks on and make sure you have equal preload on the springs (corner balancing).
![Roll Eyes (Sarcastic)](https://www.rctech.net/forum/classic_images/smilies/rolleyes.gif)
So, I think I got the front to rear weight figured out tonight. I placed a droop block on each of the two scales and set the car on them, fully loaded. The T4 took all 55 grams towards the front, on both sides of the bell cranks and top of the bumper. That seemed to even it out front to back at least.
Right, this is along the lines of what I'm thinking. Even if I adjust my preload collars to be equal (calipers and whatnot), that doesn't account for possibly varying spring rates among "identical" springs. So, equal length turnbuckles seem like an interesting experiment. I'll try it tonight.
To be clear, front = FL + FR, rear = RL + RR, right = FR + RR, left = FL + RL. When you raise one corner, putting more load on it, the opposite corner will also get more load on it, and the adjacent corners will get lighter, such that your front, rear, left, and right totals will remain the same, or extremely close to it.
Also, when you get the car all dialed-in weight-wise, try flipping it around 180 degrees and see if it reads the same. Try rotating it 90 degrees (adjusting scale positions) and see if it reads the same. When I do that, it usually doesn't, and I haven't been able to figure out why, which is another reason I've kind of given up on scales. Gravity doesn't have calibration issues.
![Laughing](https://www.rctech.net/forum/classic_images/smilies/laugh2.gif)
-Mike
I would guess the inaccuracy when rotating the car 90 or 180 degrees would be because of the scale pads not being all on the same plane (perfectly level)? Another thing I notice when using my scales it that if you don't place the tires on the scales in the same spot you will get inconsistent readings as well. If you are off 1/8" it affects the reading on the scale quite a bit. I've marked the center as best as possible and using my setup wheels I can get the wheels placed very closely to the same spot every time. One thing is for sure is I cant say that the method I use is 100% accurate. But I do manage to get repeatable results. I've been contemplating getting the longacre scales but that's a lot of money. I agree a string through the tower seems like a really good option and just let gravity do its thing.
yea, so I took a 3 year old chassis out of a box, installed some electrics, set ride height and threw on what I thought was some good droop settings, bought some wheels, painted a body, set the whole car on a scale to make sure it was a LEAST 1450 grams, went to the track, ran it. made a couple changes, ran it again.. winner. sold it. repeat (but with newer chassis)
I can't weight until this conversation is over
Thanks for the inspiration Kyle!
Hey weight Garrett. ... ain't you be a dirt guy now? What kind of weight bias you run on dirt? I think a tick of this and a tad of that may be the hot setup but I will need to post what I figure out... I could just PM you but why bother...
I ran with 2 different axle height inserts in boosted 10.5 WGT back in the Hangar DAYS for like 3 races ...epic..... honestly didn't notice until I saw it..
There should be an engineering thread for the guys that have time to do all this research and what not..
How was that Big "sexy"?
![Smilie](https://www.rctech.net/forum/classic_images/smilies/smile.gif)
Martin crisp did it, he writes books, weight, he made the website, and the xray tuning books
I still am an onroad guy, just taking a break
Hopefully I am within forum rules....
