1/14th Blue Tacon Thriller Short Course Truck Brushless Ready to Run RC Remote Contro
![Default](https://www.rctech.net/forum/images/icons/icon1.gif)
![](https://cimg2.ibsrv.net/gimg/www.rctech.net-vbulletin/700x400/80-25c109_14_thriller_sct_blue_brushless_1_293929bc4ba96aa1bba5fa4bd08e4d1c2b339a7e.jpg)
![](https://cimg3.ibsrv.net/gimg/www.rctech.net-vbulletin/700x400/80-25c109_14_thriller_sct_blue_brushless_2_8c78969422dfafefa517a424659ba5060e1b2577.jpg)
![](https://cimg4.ibsrv.net/gimg/www.rctech.net-vbulletin/700x400/80-25c109_14_thriller_sct_blue_brushless_3_249886a6744b0e88c401c23aba0647b672323c3c.jpg)
![](https://cimg5.ibsrv.net/gimg/www.rctech.net-vbulletin/700x400/80-25c109_14_thriller_sct_blue_brushless_4_0e7ee6541dd7946da45df0bc457b3df57f80d418.jpg)
https://www.nitrorcx.com/25c109-14-t...brushless.html
https://www.youtube.com/watch?v=BWCLr5YlUzY
The Tacon Thriller is a 1/14 scale short course truck. It was designed from the ground up with pure performance in mind. Performance features derived from 1/8 scale trucks and buggies have been shrunken down in size and engineered to deliver the utmost performance in a smaller scale. A 2mm thick aluminum chassis serves as the base of this short course truck. Mounted on the front and rear is 2.5mm thick 6061-T6 anodized aluminum shock towers towering over the planetary geared fluid filled differentials. Attached to the robust towers are aluminum threaded oil filled shocks providing plush and ground hugging dampening. The steering tie rods and upper and lower arms are adjustable for fine tuning of the toe and camber, effectively altering the handling characteristics of the truck.
This truck has awesome power to weight ratio. Weighing in at slightly over 2 lbs, the truck is easily propelled by the 380 sized 4500KV brushless motor. A 35 amp programmable brushless electronic speed controller delivers the current efficiently through an included 72.v 1100mah Ni-Mh battery and charger. All of this power transfers through a shaft driven four wheel drive system providing ground clawing action through the off road wheels and all terrain tires. We recommend a Gens Ace 7.4v 1800mah lithium battery for an exponential increase in power and efficiency. ?
The Tacon Thriller ready to run package also includes a 2.4ghz radio system. With frequency hopping technology, interference is a thing of the past. No longer do you have to worry about your specific channel. The radio system will automatically take care of that for you while you are focused on handling this beast of a machine.
With a body designed with short course truck looks and aerodynamic performance, combined with mud flaps on the rear end. This scale truck will put a huge smile on your face when you see it four wheel power sliding through a corner spitting dirt and debris out the rear end.
Features:
1. ?All terrain treaded tires and off-road style wheels
2. Slipper pad with adjustable gear cover
3. Aluminum threaded, oil-filled, coil-over, 6061-T6 adjustable shocks
4. 2.5mm 6061-T6 aluminum shock towers
5. Front and rear metal geared differentials
6. Brushless Tacon ESC
7. 2838 4500KV brushless motor
8. 4WD shaft drivetrain
9. Adjustable mini servo with saver
10. Steel hinge-pins with rounded front bumper
11. Tacon receiver with 2.4GHz technology
12. 7.2V 1100mAh NiMH battery with 3.5mm gilded round connectors
13. 2.5mm anodized aluminum rear and front kick-up chassis with dirt guards
14. 12mm wheel hexes
Specifications:
Scale: 1/14 Tacon Thriller Short Course Truck
Length: 360mm (14.17in)
Width: 210mm (8.26in)
Height: 135mm (5.3in)
Wheelbase: 225mm (8.86in)
Weight: 1.08kg (battery included) (2.2lbs)
Tire Type: All terrain tires
Chassis: 2.0mm anodized aluminum
Motor or Engine: 4500KV 2838 brushless motor
Gear ratio: 8.23
Speed Control: Brushless Programmable
Radio: 2.4GHz Technology
Batteries: 7.2V NiMH with 3.5mm gilded round connector, Charger included
Shock Type: Aluminum-threaded, oil-filled, coil-over, 6061-T6 ajustable
Ball Bearings: Complete
Package Contents:
100% Assembled
1x 1:14 Tacon Thriller Truck
1x 2CH 2.4Hz Transmitter
1x Battery Charger (100-240V)
1x 7.2v 1100mAh Ni-MH battery
1x Instruction Manual
Required to Run:
AA Batteries for Transmitter
![NitroRCX.com is offline](https://www.rctech.net/forum/images/statusicon/user_offline.gif)
