Xray NT1
#7531
![Default](https://www.rctech.net/forum/images/icons/icon1.gif)
You can use both cars for one box but not the best way since on the rx8 you have to move the rubber wheel opposite of the nt1. What I mean is one box for each car is best if you want to be hassle free.
#7533
Hey Jose. Doesn't RX8 also have flywheel slot on right side? Why would you have to move the rubber wheel?? You mean the the stoppers?
#7534
Yes has the slot on the same side but more towards the rght to where you have to move the starter box wheel to accommodate it. You can used the same box but its a hassle to align fly wheels from both cars.
#7535
anyone have the code for the NT1 driveshaft pin replacement? thanks
#7536
Hudy 106052
Recommend using grease on the pins as they don't wear as fast, but if you do this you will need to clean and grease regularly.
#7537
Hudy 106052
#7540
Hey what are some decent servos to get
#7543
#7544
Finally got around to building my nt1. Installing motor an clutch as to spec. Gears on pinion side are like 1 almost 2 mm off From being flush with spurs. Where should I shim behind collet ? Then re set all gap an end play Thx
#7545
pm sent
