Like Tree18Likes
Xray NT1
Old 07-09-2011, 02:03 PM
  #6031
Still looking for a 2010+ NT1 roller, pm me if you have or know about one for sale.
arix is offline
Old 07-10-2011, 04:10 PM
  #6032
Ron Goetter's Avatar
Trader Rating: 17 (95%+)
Just posted
http://www.rctech.net/forum/r-c-item...ay-nt1-wc.html
Ron Goetter is offline
Old 07-11-2011, 01:42 PM
  #6033
piper48
Guest
Posts: n/a
Default tire wear
I've been racing for awhile but this is my first year running 1/10 scale nitro on a semi serious level. Anyways I've been experiencing heavy front end tire wear. I spoke to a couple of the nitro regulars and the tire wear should be in the rear. I'm trying to get a feel for what others consider tire wear on these cars. Quick setup notes: 60 wt AE oil all around, two hole piston, 30lb front springs, 15 lbs rear springs, front shocks all the way up, rears are layed down. The track is unsealed asphalt with mountain dew compound and direction is clockwise. Tire shores 37 FL, 32 FR, 42 LR, 40 RR, 2 deg front camber, 4 deg rear camber. Oh..no sway bars all around.
Old 07-11-2011, 02:31 PM
  #6034
godzukihop's Avatar
Trader Rating: 32 (100%+)
How mant tooth side pulley are you using, 25 or 26? That will make a difference also.
godzukihop is offline
Old 07-11-2011, 05:24 PM
  #6035
British Menace's Avatar
Lay the front shocks down somewhat..... stand the rears just one hole more then the fronts.... put 30lb springs on the rear and your tire wear should even out.
at the moment your rear has more mechanical grip then the front. More grip means LESS wear!!
Watch your camber wear on your tires and adjust camber. And camber gain accordingly..... good luck
British Menace is offline
Old 07-11-2011, 11:20 PM
  #6036
piper48
Guest
Posts: n/a
Thanks guys. I bought the car used and have been running it as is. The side pulley is a 25t. I take it with the 25t the front axle rotates at a faster rate in comparison to the the rear? The spring rates are a bit uneven but the car drives great the way it is. I'll try a heavier spring in the rear and go from there.
Old 07-12-2011, 05:28 AM
  #6037
godzukihop's Avatar
from the XRAY set up manual.
The “overdrive ratio” (ODR) is the ratio between the front DTR and the rear DTR, and is affected by the mid-side pulley used on the NT1.
Overdrive ratio impacts the difference in rotation speed between the front and rear wheels.
Depending on the mid-side pulley being used, the FDR values will
be different between the front and rear of the NT1:
• Rear DTR of the NT1 is permanently set to 2.05.
• When using the 26T mid-side pulley, both front and rear DTR ratios are 2.05.
This gives a 1:1 overdrive ratio.
The front and rear wheels rotate at the same speed.
• When using the 25T mid-side pulley, the front internal ratio (DTR) becomes 1.97.
When compared to the rear DTR of 2.05, the overdrive ratio now becomes 1.04:1.
The front wheels rotate 4% faster than the rear wheels.
OVERDRIVE RATIO (ODR)
DTR RATIO
MID-SIDE PULLEY
26 25
Front DTR 2.05 1.97
Rear DTR 2.05 2.05
OVERDRIVE RATIO 1 : 1 1.04 : 1
Old 07-12-2011, 02:11 PM
  #6038
piper48
Guest
Posts: n/a
DTR RATIO
MID-SIDE PULLEY
26 25
Front DTR 2.05 1.97
Rear DTR 2.05 2.05
That my friend is great information. I'll leave it setup the way it is and run the 26t instead. It'll probably hurt my launch off the exit but a small price for even tire wear. Nice Avatar Godzukihop . Thanks again.
Old 07-12-2011, 02:16 PM
  #6039
kmichael's Avatar
That was great information
kmichael is offline
Old 07-16-2011, 03:46 PM
  #6040
rowveg36's Avatar
Trader Rating: 21 (100%+)
guys, where can i buy a capricorn clutch bell that fits nt1 pinion gears? thanks for the info:
rowveg36 is offline
Old 07-16-2011, 04:30 PM
  #6041
Serpent-Dan's Avatar
Trader Rating: 18 (100%+)
Kamikazercracing.com
Serpent-Dan is offline
Old 07-16-2011, 09:39 PM
  #6042
PM SENT
laptraffic is offline
Old 07-16-2011, 09:41 PM
  #6043
PM sent
Old 07-21-2011, 10:25 AM
  #6044
Still looking for a 2010 NT! Roller, PM me if you want to sell yours.
arix is offline
Old 07-22-2011, 10:01 AM
  #6045
Also looking for a 2010 or 2011 NT1 roller in mint condition. Would prefer package deal with spare parts or even 2nd car. Will pay a fair price, I am no low-baller. Please PM me with details.
Thomas
bluelevel is offline
