The Speed Shop(Birmingham, Alabama)
#3016
#3024
![Default](https://www.rctech.net/forum/images/icons/icon1.gif)
It's a start. Getting it back going. Got a couple engines and some work on the table. It's going to get better and better. Thanks guys! Remember to come over to facebook and like our page: https://www.facebook.com/pages/The-S...269137?fref=ts
![](http://i1383.photobucket.com/albums/ah284/alanburton1980/Mobile%20Uploads/2014-11/B173F954-D5B0-471D-9EA2-348DC6A8FF52_zpsv7njcsuz.png)
#3026
Just wanted to post some updated pictures of what's involved and some of the things that are found on cars when looking over them. This car happens to be 2-3 races old. Good shape parts wise but it wasn't built to stay together. Clutch nut, bell screw, and other screw really loose. Some stuff way to tight causing binding. The biggest thing I found was the clutch. Similar to losi. It's way worn and when it gets below a certain measurement it really changes the feel and handling of your car, yep the handling. That's something the Adam Drake showed me years ago. So always keep your clutch in spec. The engine only 2 gallons old shows some signs of debri passing through and is low on compression. The receiver is hard mounted in the box and that's not good, and a electronic switch. They work but I'm not a fan. On this service for $60 the car comes down like this. Bearings are checked and lubed, fresh fluids, and anything that's needed.
![](http://i1383.photobucket.com/albums/ah284/alanburton1980/Mobile%20Uploads/2014-10/139C7402-269D-4746-8A8D-93A452484147_zps1qngktp4.jpg)
![](http://i1383.photobucket.com/albums/ah284/alanburton1980/Mobile%20Uploads/2014-11/1E67909D-B5D0-400E-92AC-F011DA890FCC_zpstfuoikvj.jpg)
![](http://i1383.photobucket.com/albums/ah284/alanburton1980/Mobile%20Uploads/2014-11/35B912DF-6F9C-449B-BD83-56584A8D01BA_zpswipjkmh5.jpg)
![](http://i1383.photobucket.com/albums/ah284/alanburton1980/Mobile%20Uploads/2014-11/08B14D0C-2139-4675-8B1B-AF1BFB6A067B_zpswzrblnxo.jpg)
![](http://i1383.photobucket.com/albums/ah284/alanburton1980/Mobile%20Uploads/2014-11/5C16619A-8681-448A-BE4E-CD23377E33D2_zpsfkjinh5t.jpg)
![](http://i1383.photobucket.com/albums/ah284/alanburton1980/Mobile%20Uploads/2014-11/0A162F0F-14CC-4C3F-9ACB-12AA470FC289_zpsksbapder.jpg)
![](http://i1383.photobucket.com/albums/ah284/alanburton1980/Mobile%20Uploads/2014-11/0E6C086E-56F1-466C-B77A-0F7DC64C6C26_zpsjjsyfepb.jpg)
#3028
#3030
loving the pics of your service you are providing.
noticing you mentioned that the novarossi in the D812 you had in was 'low in compression'
i assume this was deduced from when you were putting the psiton in the sleeve and seeing how far it got. this is interesting cause i am wondering if my novarossi has low compresison too. what distance did you measure from the top of the sleeve to the piston? im getting around 3.4mm.
thanks
thanks
