The Speed Shop(Birmingham, Alabama)
#2986
Speed Services
Factory Race prep $60/ plus return shipping
This service includes a complete tear down for your race ride. We put our setup or yours on it. We will create a list of parts needed for you and replace all needed parts upon your approval. The Speed Shop includes fresh shock oil with shock rebuild, and fresh diff fluid with the Speed Shop's diff rebuild. We make sure everything is smooth, free, and tight. All areas are checked that need to be loc tite and we top that off with a factory clean job using all high quality products. You can have the same caliber car that the top pro's race with on any given weekend!(parts not included)
The Speed Prep $30/plus return shipping
This is a quick service for our regular customers. This service is designed as a in between before your next Factory race prep. The Speed Shop will Give it a Factory Clean, using all high quality Products. We will then check diffs and rebuild shocks making sure everything is up to par. We will install new clutch/clutch bearings, new air filter, set ride height, camber, gear mesh, and check over all the screw so your ride is Speed Shop approved for your next local race!(parts not included)
Speed Shop Full engine break-in $90/plus return shipping(includes fuel)
Let the Speed Shop save you the trouble of that pesky break-in and do it in house! We have break in benches set up and offer the fastest turn around time in the industry. We have real world race level experience that stands behind our break ins! All engines done inside and in controlled enviroment. We put 1500cc-2000cc on the engine for you. We use our version of the heat cycle method. This option is 6-7 hours of running and several heat cycles.
Speed Shop Race Plus break-in $60/plus return shipping(includes fuel)
Let the Speed Shop save you the trouble of that pesky break-in and do it in house! We have break in benches set up and offer the fastest turn around time in the industry. We have real world race level experience that stands behind our break ins! All engines done inside and in controlled enviroment. We put 1000cc on the engine for you. We use our version of the heat cycle method. This option puts 2-3 hours of running on the engine and several heat cycles.
Speed Shop Race Prep $30/plus return shipping(includes fuel)
Let the Speed Shop save you the trouble of that pesky break-in and do it in house! We have break in benches set up and offer the fastest turn around time in the industry. We have real world race level experience that stands behind our break ins! All engines done inside and in controlled enviroment. We put 500cc on the engine for you. This option is designed to get things going for you the racer. This involves close to 2 hours of running, and several heat cycles. This option will need more break in on track.
Speed Shop engine rebuild $60/plus return shipping
This service includes tearing down the engine and inspecting each part. We clean the engine to have it looking fresh. Our guys install new high quality ceramic bearings front and rear and top that off with a light to medium race pinch. This is the same service we use on our race engines to keep them in top shape at events all around the world!
Speed Shop Sleeve resizing $20/plus return shipping
For this we use only the best! We have a top of the line BMR racing products resizing tool. We take your complete engine, clean bearings(or we can install new) clean the internals, polish out any small scratches on the piston/sleeve and give you what we feel is the perfect pinch. We believe the this can only be accomplished by getting your complete engine and actually feeling the piston/sleeve at temp. We don't believe in the "super tight" theory. With the Speed Shop you get whats going to run best on the track!
Speed Shop's Wrap Install $25/plus return shipping
The Pipe clean $10/plus return shipping
Send us those old dirty, beat up pipes. If it's got tarnish, fuel, dirt, greae baked on we can get it off and make it look like new again. We let it soak in a chemical bath for 8-10 hours, without hurting the coating on your pipe. This improves run time as well because that old stopped up baffle is going to be breathing like new again! After that we clean it up and top it off with a good polish!
Speed Mounting Tire service $7 per set/plus return shipping(includes glue and cleaner)
Never worry about your tires coming unglued during that race! We have years of national level race experience and understand what it's like to prepare and work hard only to have a pre mount come unglued. We put air holes in the tire, clean the tires and rim and glue your tires. You then have a tire that is track ready and done by the best! No order to small or large!
#2988
do you have a address ?
#2990
check pm
#2991
Agama a8
Enjoyed this buggy in the past. Last race was the psycho nitro blast 2012. Super rough track. Only aftermarket part I used was competition racing products shock pistons which made a huge difference over stock. Made it to the a main from the b and finished 7th I believe.
#2992
Currently working on getting settled in the new shop and getting things going. To my surprise I have a fair amount of work already on the way. Once I get started I'll get pictures posted and let everyone see the new Speed Shop. Found this old video looking around back when the shop was in Alabama. I always like to show guys what went into the work that we did and how the shop was organized and set up.
http://www.youtube.com/watch?v=9g9qlvVglsg
#2996
Do you have a website?
#2997
I think this time I'm going to start with social media like Facebook,ect. So many people available that way.
https://www.facebook.com/pages/The-S...269137?sk=info
