The Infiniti IF8 buggy
#78
![Default](https://www.rctech.net/forum/images/icons/icon1.gif)
The kit comes with one set of sway bars for front/rear (2.4/2.8), and a few options for shock pistons. Besides the 32* and 35* steering rack stopper i don't think there are many tuning options included with the kit
Shock piston options
6 x 1.2
6 x 1.3
8 x 1.2
8 x 1.3
5 x 1.4
blanks
#79
So far no diff leakage with 35 minutes of run time. Both F/R diff's were still 47 grams full of fluid
I know HB diffs were prone to it unless you scuff the face. I didn't do anything special with the IF diffs, fingers crossed. Also, diff maintenance is a nice change of pace from the HB lol. 👍🏻
#80
Decided to cancel my pre order on this last minute. Just couldn’t get past the design of the blocks being mounted directly on the chassis. Screws are gonna wear quick and be pain to change. Other than that buggy looked good. Other thing I don’t like is what’s the cost of spares gonna be. I assume RC1 is getting spare parts at some point. For those that purchased please post some unboxing pics.
I designed my own gearbox from scratch, you can mount the screws for the blocks on the front side, but then you are limited to how much you can reduce the front and rear pivot. The Tekno has the narrowest front and rear pivot, and they couldn't even design the gearbox without making the A and D block mount with screws from underneath. There is some give a take here. Gaining access to the screws for the B and C block when the car is fully assembled is impossible with them being mounted from the side. With this design you can remove all suspension blocks with ease and the screws are right there on the underside of the chassis. These are m4 bolts as well which can take a beating, and have a deep socket depth so even if they do wear there is plenty of depth for the allen wrench.
#81
