View Poll Results: JPRaceway : On-road or Off-road?
On-Road
![](https://www.rctech.net/forum/images/polls/bar2-l.gif)
![](https://www.rctech.net/forum/images/polls/bar2.gif)
![](https://www.rctech.net/forum/images/polls/bar2-r.gif)
![](https://www.rctech.net/forum/clear.gif)
60
69.77%
Off-Road
![](https://www.rctech.net/forum/images/polls/bar3-l.gif)
![](https://www.rctech.net/forum/images/polls/bar3.gif)
![](https://www.rctech.net/forum/images/polls/bar3-r.gif)
26
30.23%
Voters: 86. You may not vote on this poll
The Big Locked Thread
![Default](https://www.rctech.net/forum/images/icons/icon1.gif)
for clarification once again, ANY brand of nitro engine can be used in the Novarossi Cup.
see you all at The Farm Raceway on March 25...
thanks
thanks
![outLaW^ is offline](https://www.rctech.net/forum/images/statusicon/user_offline.gif)
Looking for Futaba servo 3003 budget ko 300. please txt me at 0919293288 of PM me
![Mach 1 Racer is offline](https://www.rctech.net/forum/images/statusicon/user_offline.gif)
Originally Posted by nad138
Mga Bradir,
Sinong Hobby shop (phone#) ang nag-ca-carry ng TRAXXAS kits (REVO, TMAXX) at parts support na rin.
Salamat sa tulong ninyo.
Nad
Nad
![Armstrong is offline](https://www.rctech.net/forum/images/statusicon/user_offline.gif)
rnold/oldskul: kudos to you on the adjusted rules. looks im gonna get my ride ready for this. ano ba suggestion niyo na ok na 23 tamiya motor for the 4wd GT class if we will be running at JP? not really familiar with the tamiya motors. i will extend the invitation to the other ep boys given the new ruling! cant wait!
![Nodding](https://www.rctech.net/forum/classic_images/smilies/nod.gif)
![ROBORAT is offline](https://www.rctech.net/forum/images/statusicon/user_offline.gif)
am selling my fm 40 mghz k.o propo mars ex-1 transmiter with reciever its in good working condition gauranteed no glitches price is 5k. if interested u can sms me at 09189633109 or 09277901470 tnx
![cave_man is offline](https://www.rctech.net/forum/images/statusicon/user_offline.gif)
IV.4WD GT Stock 23 Class
•Any brand 4WD EP chassis are allowed.
•Only the Tamiya 23-turn motor (all variants) is allowed to be used in this class.
•Motor brushes and springs must be from Tamiya
•Any brand/make/capacity 6-cell battery packs are allowed except Li-Po batteries.
•Only Tamiya 24mm and 26mm tires are allowed.
•Any brand body shell allowed.
•Weight limit of 1,500 grams (ready to race) will be imposed
can we use aftermarket inserts and rims? in GT class? i hope pwede
robo: glad you asked that early para maka kuha narin ng 23t motor if you guys will run in this series.
![Smilie](https://www.rctech.net/forum/classic_images/smilies/smile.gif)
![Wink](https://www.rctech.net/forum/classic_images/smilies/wink.gif)
![|JayFlores|2 is offline](https://www.rctech.net/forum/images/statusicon/user_offline.gif)
Woohoo! It's that time of year!
Robo: Hi chief. Sali na!
![Spiderman](https://www.rctech.net/forum/classic_images/smilies/spidey.gif)
![Maddafunker is offline](https://www.rctech.net/forum/images/statusicon/user_offline.gif)
looking for good condition tx and rx 4channel for rc plane
pm me if you have
thanks
pm me if you have
thanks
![torogi is offline](https://www.rctech.net/forum/images/statusicon/user_offline.gif)
madda: eto nga, nagtatanong na ng specifics.
mga tamiya boys: are the RZ, TZ and BZ motors rebuildable? i hope so para naman masulit ang mga motor na bibilhin namin if ever. kinda expensive to buy a new motor when the comm is worn down and out of round. personally its a major consideration for me.
kay mang's sa pitshop 09175331943 try mo contact baka makahanap ka ng parts
Mga Bradir,
Nad
Nad
*JRX-S by Team Losi P3,000.00k
One rolling chassis with Katana SL 23T motor, 64P (37T) Pinion, Big Battery Tray, Aluminum, XL Cells: JRX-S, Original but used painted body for practice. Been using it for rear wheel racing and tamiya 550 motor mostly so needs Drive Belt 330mm, White: JRX-S to make it four wheel drive. Free pinion 17T, 25T, 28T, 35T, 38T, AND 44T (all 64Pitch).
Brand new spares;
#A-8053 Alfa 156 GTA sedan body w/ masks
#LOSA4253 Sway bar plastics only:JRX-S
Pulley Set Front/Re/Idler: XXX-S, JRX-S
Drive Belt 390mm, Gray: JRX-S
0 degree Front Spindles & Carriers-Graphite
Spares;
Chassis Plate Graphite, Spindle Carrier Bushings & Hardware,
Steering Posts Aluminum, Steering Sector Arm Aluminum, Drive Belt 390mm Gray, Diff Tube Aluminum, Center Shaft Set 4mm, Center Pulley Hub-Pin Drive Aluminum,
Center Pulley Set & Drive Hub, CVD Set Front & Rear, LCD Drive Set (2), Body Post & Bumper Set, Rear Top Plate Graphite, Front Top Plate Graphite, Bulkhead/Motor Mount Aluminum, Center Bulkhead Aluminum, Front Shock Tower-Graphite…..
Can’t put anymore. Let’s just say it’s about 80% complete spare parts to make another kit.
*Team Orion Katana SL 23Tmotor w/ deans plug (used)
*Team Orion Katana TL (can only w/ deans plug)
*Team Orion Revolution 8x2 mod motor w/ deans plug (half used) P800.00
*Top Racing Swift 7x2(7TD-Rpm) slightly used w/0 endbell (one run only)
*Ofna micro fail safe unit (3 weeks used) P600.00 Reserved
*Futaba s3003 (almost new) P700.00 Reserved
*Team Orion #41393 revolution motor springs hard-8 coils .30mm (bnew) P160.00
*Reedy Quasar brushes #729 (bnew) P225.00
*3x Team Orion #41090 revolution standard brushes serrated enduro
10-30runs (bnew) P205.00ea
*5x Hpi racing #31324 R2 23T brush for TL/SL (bnew) P190.00
*Kyosho V1RRR carbon upper plate (bnew) P1,800.00
*Kyosho V1RRR Center Bulk VZ211 (bnew) P215.00
*Kyosho V1RRR Evo Center Bulk VZ211B (bnew) P215.00
*Kyosho V1RRR Shocks (4pcs bnew) P4K
*SOLD
TRAXXAS REVO 2.5R (P8.5K), Sanwa M11 antenna (P450.00), Sanwa M11 40.65MHz
crystal FM on Tx Module (TM-201CW) and Rx (RX-311) (P2.5K).
Brand new spares;
Spares;
*SOLD
![Jezp is offline](https://www.rctech.net/forum/images/statusicon/user_offline.gif)
![Batman](https://www.rctech.net/forum/classic_images/smilies/batman.gif)
![ratBu 2 is offline](https://www.rctech.net/forum/images/statusicon/user_offline.gif)
VR2L_dude..nagparegister ka na ba sa ACADEMY OF MODEL AERONAUTICS? kailangan natin yan para me insurance tyo sa flying....
![Rotating Tire](https://www.rctech.net/forum/classic_images/smilies/tire.gif)
![Stick Out Tongue](https://www.rctech.net/forum/classic_images/smilies/tongue.gif)
![Big Grin](https://www.rctech.net/forum/classic_images/smilies/biggrin.gif)
