Jake's R/C Pro-Am. Topeka's indoor offroad.
#9286
![Default](https://www.rctech.net/forum/images/icons/icon1.gif)
Yea last night was a blast. To bad your 4wheeler broke. Cant wait till next saturday.
Any one interested in running a super stock class for corr truck?
13.5 motor
speedo must be in blinky mode?
A little more power and speed and would make for some fun close racing just like 17.5.
Anyone? 4 makes a class!
Dustin are you ok with this?
![Big Grin](https://www.rctech.net/forum/classic_images/smilies/biggrin.gif)
![Nodding](https://www.rctech.net/forum/classic_images/smilies/nod.gif)
![Rotating Tire](https://www.rctech.net/forum/classic_images/smilies/tire.gif)
13.5 motor
#9288
yo bond im running open corr
#9289
Bond- There technically shouldn't be any "slowing" of the 17.5 motor when it reaches 180deg. It should show weakening signs when it exceeds 225+deg.
Assuming that your gear-ratio is right, this overheating may be caused by a drive-train drag. Check all your bearings, especially your Hubs. Check your Tranny Case for over tightened screws. Make sure your drive-train spins completely free.
I run a much higher amp dump running a 17.5 in a TC @ 150deg.-165deg. One small drag and up goes the temps and speed loss.
Hope this helps.
Hope this helps.
#9290
We have a ballistic 17.5 that is just slow. I have the same timing and gears as in my son's SC10 another SC10 and you can see from the sidelines that it is just slow. I swapped the ESC before last Saturday and the ESC ran fine in my truck. That truck's problem was me. What do you think? This is a motor that had to have the sensor board replaced and then I had trouble with a stronger servo overwhelming the ESC. Maybe it got hot earlier, I don't think it got that hot, it was not running hot Saturday. Hate to complain to Novak that it is slow. If it was the gear train, I would expect heat issues.
#9291
[QUOTE=theDover;11226382]Bond- There technically shouldn't be any "slowing" of the 17.5 motor when it reaches 180deg. It should show weakening signs when it exceeds 225+deg.
Hope this helps.[/QUOTE
I have checked all the above and tranny is free .... I have had this same result in an SC 10, xxxsct, and now in my Kyosho. Motor gets between 160-180 and it loses power. I am not saying it quits or slows to a crawl but it won't clear the jump. As far as you having a higher amp draw in a touring car...you sure about that over a corr truck with the big tires?? Anyways thanks
#9298
Does anyone have a SC10 gear diff they dont need? I need one asap! the new layout is . . . .
#9299
Oh yea the M12's are in stock!!!! call for pricing
