Jake's R/C Pro-Am. Topeka's indoor offroad.
#6241
well it seems i will need some help to get both my tekin systems setup right....still confuzzed
#6246
Kool thanks
#6247
I was wondering if someone could help me out here, I've noticed some of the off brand motors aren't rated int there turn spec but instead sold as there KV rating.... would a 2726kv motor be close to a 17.5? If not what would the turn rating be on that?
#6249
Sure as long as you use an six tooth press on pinion Chris! HA HA!
Dave K.
Dave K.
#6250
I don't think Stevie's high buck Tekin RS (in spec mode) and his fancy new viper(?) motor was any faster than my low buck Losi Xcelorin 17.5 combo.
#6251
I think once you remove all the fancy timing adjustments being sent to these 17.5 brushless motors that you'll find that their all very similiar in performance. One might have a tad more RPM than the other but running temperature is everything nowadays and you can only gear so far.
