Team Losi JRXS
#5853
![Default](https://www.rctech.net/forum/images/icons/icon1.gif)
Originally Posted by brians11
it's certainly not a requirement, all I was saying is that they aren't limited to foam tires and carpet racing
#5854
Originally Posted by STLNLST
These things are like gold huh?????
Billy is supposed to be receiving a shipment today. Had to buy them back from distributors.
Do you have a recommended insert for SW?
Bill
#5855
Todd, Do you run a power cap on the LRP QC2?
#5856
Originally Posted by Scott Welte
Todd- Come by and pick me up on your way
I need a vacation, although I was just away at the Reedy Race.
I need to get to SpeedWorld, the timing is never right.
![Laughing](https://www.rctech.net/forum/classic_images/smilies/laugh2.gif)
#5858
is there a front one-way diff for the jrxs already? sorry kinda outdated..
#5859
Hi Guys
On Josh newman's set up, and some others, I have seen that on their shock data they say for eg. piston size 56 drilled, what does the drilled bit mean?
Geoff
Geoff
![Confused](https://www.rctech.net/forum/classic_images/smilies/confused.gif)
#5860
Man, how come I can't find Numanville on a map anywhere...? Do you mean Newman, CA?
http://www.mapquest.com/maps/map.adp...te=ca&zipcode=
#5861
Lol.. i'v been trying to find that place too.. maybe if we call the number provided they'll be able to give directions...
![Nodding](https://www.rctech.net/forum/classic_images/smilies/nod.gif)
![Stick Out Tongue](https://www.rctech.net/forum/classic_images/smilies/tongue.gif)
#5862
Originally Posted by losiboys
Hi Guys
Geoff![Confused](https://www.rctech.net/forum/classic_images/smilies/confused.gif)
Geoff
I find it interesting that he used a 'relatively' soft setup..
#5863
when someone talks about using a "drilled" piston ... what it means is that they have taken a piston with small holes (usually a 60) and taken whatever drill size they mention and used that to drill out the holes in the piston to that size...
For example... if someone said they ran a "drilled 56" that means that all three holes were drilled out using a #56 drill bit...
Things can get a little more complicated ... you might see someone run something like a "drilled 557" or something or other...that means two of the holes are drilled out using a #55 bit and one hole using a #57...
Why drill out the pistons? There are two main reasons:
1.) the hole you get from a drill bit can be a lot more consistant than a molded hole...sometimes molds don't line up...stuff builds up in the molds...etc... if you drill out your pistons your hole size will always be the same...
2.) Because of the molding process, a molded hole in a piston will tend to be a tiny bit bigger than a hole that is drilled in the piston... this means a "drilled 56" will have slightly smaller holes in it than a "molded 56" .... this can be a nice tuning aid ...sometimes you want just a little bit more dampening than a standard piston and that's when a drilled piston might be worthwhile in trying
Hope this all helps clear things up instead of confusing you all even more
![Smilie](https://www.rctech.net/forum/classic_images/smilies/smile.gif)
#5864
#5865
Hope this all helps clear things up instead of confusing you all even more![Smilie](https://www.rctech.net/forum/classic_images/smilies/smile.gif)
Geoff
