Speedmerchant Rev.4
#946
![Default](https://www.rctech.net/forum/images/icons/icon1.gif)
I know they are not droop screws, but I knew what he meant. I should have corrected that, but Ed said it first
![Stick Out Tongue](https://www.rctech.net/forum/classic_images/smilies/tongue.gif)
![Big Grin](https://www.rctech.net/forum/classic_images/smilies/biggrin.gif)
#947
So more droop more bite. Is that correct?
#948
more pod droop means the car will transfer more weight wehn you come off power to the front end of the car. Generally, it will make the car turn more off power.
#950
I have a ride height question. I did a search and found what roughly to have for ride height. My question is should the rear pod plate be level with the main chassis or should there be some angle.
#951
the union between the pod and main chassis should be the lowest point on the car. This is known as "sag." Sag makes the car easier to drive and makes it plant the front more off power and the rear on power. If the car is really pushy on power you can take some sag out of the chassis.
As far ride height goes, more than 3, less than 4. You can go as high as 4.5 at the very front and back of the car, but if the bite is high it might be dicey.
#952
whoops double post
#953
What a hacker cant even post correctly, $10 he doesnt know which way to turn the wheel when the car is coming at him... ![Wink](https://www.rctech.net/forum/classic_images/smilies/wink.gif)
smojoe- Droop really doesnt affect on power quite as much since all it does is limit the expansion of the shock, and when are you accelerating you are compressing the shock so droop really does not have an affect on on power steering. The center shock is mainly what affects on power steering, and the side springs affect it a bit (that is if you are turning at all while accelerating).
#954
Here's a question for all the veteran speed merchants out there,
I have nearly finished building my Rev 4.5. I ground down the steering blocks by 0.030" to run smaller tires. Mounting some front tires last night, it seems the inside of the wheels are slightly interfering with the top of the old skool arm (where the king pin comes out). It looks like I could probably just grind away a small amount of material to get the clearance I need. Is this step a normal part of the steering block mod, or did I go overboard in cutting down the blocks? As an alternative to grinding down the top of the arm, I could reshim the blocks on the king pin to move them up a little. Thoughts? Thanks.
Andy
Andy
#956
Originally Posted by Scrad
Yes, you should have to grind a little bit on the top of the arm. You should have also put some spacers on the kingpin.
Andy
#957
35 wt. AE oil
AE red center spring
sides are:
10,000 wt. ofna diff oil
.23 speedmerchant side springs
CRC purple fronts and grey rears
.22 front springs
for some reason it seemed really lazy coming into the corners
#958
Just got my Rev 4.5...
THANK YOU BRUCE!!!
THANK YOU BRUCE!!!
![Smilie](https://www.rctech.net/forum/classic_images/smilies/smile.gif)
#959
center shock is CRC unit with:
35 wt. AE oil
sides are:
.22 front springs
35 wt. AE oil
sides are:
.22 front springs
#960
THANK YOU BRUCE!!!![Smilie](https://www.rctech.net/forum/classic_images/smilies/smile.gif)
THANK YOU BRUCE!!!
