Tamiya FF03
#3272
![Default](https://www.rctech.net/forum/images/icons/icon1.gif)
cool build man, liked reading that! I’m using the car at a makeshift track in a parking lot, low grip with rubber tires so I need flex and the reinforced parts aren’t needed, but the weight savings you had was great! I ordered paint and bearings for the kit, should come together soon. I like this chassis so much I’m going to buy hop ups often lol
and that’s cool you are sticking with FWD 👌 it’s always been the most fun in my opinion
#3274
I set a rule for my group where race schemes are a must.. so it's probably going to be boxart for this body. Mostly white, with a medium grey hood and roof. Lots of sponsor decals. I spend so much time on my chassis (re)builds that I don't normally have time to come up with my own paint schemes. Especially when one is supplied for me. Lazy, i know... Lol
#3275
I run a parking lot(garage) as well. I found, thus far, the stock tires worked very well. This year I'm trying out the Gravity RC USGT Spec tire, nice and cheap compared to the Tamiya tires. Car handled fairly well considering it was box stock. I did manage to break a couple of suspension mounts from getting rear ended by an out of control XV-01.
I did find that the car was too flexible for the parking lot. Added the rear stiffeners, TRF suspension links, alloy/carbon steering rack, and TRF shocks. I'm on the hunt for the Tamiya stabilizer bar set for it currently, might be made of UNOBTANIUM though. Lol
#3278
#3279
Just seen this and done the change. THANK YOU! This has been driving me nuts for months since i changed to reinforced plastics.
#3280
#3281
I have the FF-03 stabilizer set but I only used the one for the front. My rear suspension is already stiff and the doesn't need it anymore in my opinion. Drives the way I want it.
#3283
So I was wondering if anyone has ever tried this?
https://www.thingiverse.com/thing:2885182
some posts up i asked if front TRF arms can be used on FF03... and someone shared this link. Having looked at how it mounts up, with just 2 screws from left and right, 1 on motor support plate and 1 on heatsink, not certain if it will oscillate when the car is in motion, with suspension moving and all that.
Any thoughts on this?
![](https://cimg4.ibsrv.net/gimg/www.rctech.net-vbulletin/1215x762/whatsapp_image_2020_04_11_at_06_34_58_886fa4165003097d9342e3f2a62c423c6acc8d95.jpeg)
![](https://cimg5.ibsrv.net/gimg/www.rctech.net-vbulletin/1180x782/whatsapp_image_2020_04_11_at_06_35_36_8cae3e4324b0a5570a122ef5ead625b9085df66b.jpeg)
![](https://cimg7.ibsrv.net/gimg/www.rctech.net-vbulletin/1179x781/whatsapp_image_2020_04_11_at_06_36_03_4064d1a9614d23708195b45fc1d8b4a07bad5d84.jpeg)
#3284
#3285
The suspension arms used on the FF-03 are from the TRF416, so they are TRF arms. As for the upright shock tower, it does look like it could swivel back-and-forth if the shocks aren't attached perfectly in-line with the screws that attach the tower to the chassis. However, the bigger concern is that 3D-printed part is made from un-reinforced ABS plastic and will flex under load, behaving like an un-damped spring. If you really want upright front shocks, replace your FF-03 with a FF-04 -- but personally I don't think it makes any difference in the real world.
