Pro 10: 235mm Le Mans Prototype Pan Car Discussion
#226
![Default](https://www.rctech.net/forum/images/icons/icon1.gif)
Do you have some pictures of that car? I would like to see it...
#229
Looks good!!!
Is this based on a RC10L2? If you want to sell it, let me know
![Big Grin](https://www.rctech.net/forum/classic_images/smilies/biggrin.gif)
#231
hey joost, the top podplate for the three way conversion you have seen on my RC10L2.5 is the newer topplate and is from the same designer as the above car.
#232
@tallyrc: Okay man, I understand...
@Alexander: I already thought that. I recognized the chassis from your pictures...
#235
#237
just picked up one RC10L2 from the forum, never run before.
i have lots of 3s2200mah lipo from flying, wanting to try it out on my L2.
on board the 10L2;
-Hobbywing 5.5T with 60a esc
-Gear ratio 108/20 5.4:1
-Tire 63mm
-lipo 3s2p 4400mah.
Will this set up smoke the esc or thermal cut the motor ???? Is it possible to run 3s on 5.5T?
any input is greatly appreaciated.
Cheers!!
![Stick Out Tongue](https://www.rctech.net/forum/classic_images/smilies/tongue.gif)
on board the 10L2;
-Tire 63mm
-lipo 3s2p 4400mah.
Cheers!!
#238
your rollout seems to be ok with a 5.5t but the question is how big is the track?... Second, don't use 64dp spurs and pinions.. they will strip easily.... use 48dp. Does the pod run free? The motor wires seem to be quite big, that could couse some problems with the pods movement if you are not carefull.
If this is your first pancar than the speed will be more then enough. The question is, can you get the right car setup for the specific track to be able to get that power to the ground and through the corners.
#239
![](https://a1.sphotos.ak.fbcdn.net/hphotos-ak-ash4/318446_10150290007752921_626432920_7986460_6743362_n.jpg)
#240
Thanks Phil
To explain that picture... that was the pro10 class during our national race today.
Too bad my brushed esc was short circuit due to water that got inside the balloon. I only needed 1 lap to finish third place total....... my esc fried during the 2 practise laps just before the start... DOH!
![Laughing](https://www.rctech.net/forum/classic_images/smilies/laugh2.gif)
