Awesomatix EP Touring Car (A700 Shaft Drive) >
Like Tree148Likes
Old 01-22-2016, 01:37 PM
  #9136
WesRaven's Avatar
Originally Posted by hobbs
Ok... guys,
I just cannot make the gear diff & dampers from leaking, no matter what i do (including changing new o rings).
Is there any special way or trick you guys are uaing besides follwoing the instruction from manual??
Just in case, green slime is not stopping the leakage.
I have battled oil seepage in my dampers and diff for a while too and have tried many methods without complete success. I've never had an actual leak where I can see the oil dripping out, but I do commonly get enough seepage around o-ring areas that attract dirt and road grime. So, you're definitely not completely alone with this. Here's what I'm currently trying (will find out this weekend how well it works)
For the diff: I've noticed that I always have one side that seeps oil from the outdrive (and I do loc-tite both vent screws). I believe I'm overfilling the diff, so when the oil heats up during a race it forces itself passed an o-ring. Per some instructions a few pages back on this thread I used a lighter to heat my diff up to around 120F and a surprising amount of oil came out the vent screw.
For the dampers: I'm assuming I'm dealing with a similar issue as the diff where the fluid wants to expand. I'm trying out the new P45 sponges instead of the set screws that used to go down the center of the vane. From what the team drivers say, this sponge allows the oil to expand and contract without forcing out the o-ring.
I'll report back after this weekend of racing to see how much these methods helped.
WesRaven is offline
Old 01-22-2016, 01:40 PM
  #9137
DamageNZ's Avatar
Thanks guys, thats great. I'm still running the stock ball-studs so I'll go with the Kyosho ones and see how we go.
Thanks for the help - greatly appreciated
DamageNZ is offline
Old 01-22-2016, 04:09 PM
  #9138
So i have started to attend some "bigger" races, and have been having traction rolling issue's when traction comes up. I will often glue the side walls of my front tires and usually kill a bit of dual rate. But what are some minor changes i can make to my set-up to help me out. I run Mike Gee's 17.5 set-up from the 2015 roar champs at horsham. I run 500 cst not 650 and a little more rear toe as my local track is low-medium traction.
Doug S
doug smith is offline
Old 01-22-2016, 04:44 PM
  #9139
Doug S
Wider front track
Narrower rear track
Glue front side walls
Lower roll center
Reduce camber gain
Soften spring rate
Reduce camber
Lighter body
malkiy is offline
Old 01-22-2016, 09:42 PM
  #9140
geeunit1014's Avatar
Trader Rating: 14 (100%+)
Doug S
Glue is the best thing. I had glued tires at that race. At that race I could have not glued and chased the setup and still risked being tippy, so I glued instead, don't have to worry about flipping and be aggressive with the setup and driving. This is my philosophy any time you deal with being tippy.
If you want to try another change that may help, add a 1mm shin under the am06s (don't forget to reset all the alignment)
geeunit1014 is offline
Old 01-23-2016, 01:51 AM
  #9141
Originally Posted by malkiy
Wider front track
Narrower rear track
Lower roll center
Reduce camber gain
Soften spring rate
Reduce camber
Lighter body
Thank you both, that is the kind of information i was looking for. I felt like i was using glued sidewalls as a crutch for a faulty setup.
Doug S.
Old 01-23-2016, 06:30 PM
  #9142
I hope you guys are using those blitz(0.5mm) 60gram bodies instead of the hefty 90gram so called lightweight bodies... No traction roll after that.....
bertrandsv87 is offline
Old 01-23-2016, 07:21 PM
  #9143
R/C Tech Elite Member
nexxus's Avatar
Trader Rating: 315 (100%+)
I ran my Evo 2 last night thought I had sorted the suspension binding issue but it raised it's ugly head again in qual 2, ended up changing out the back shocks from the D2.1 to my old R6/L6 sealed units and the issue went away so the problem is in the actual damper unit. Car started off tail happy ended up the ride height was wrong so fixed that and dropped the inner camber link on the back from 3mm to 2mm and bam car was hooked up. Did a PB for the last two finals and won the night for 21.5. Getting there slowly with this car.
nexxus is offline
Old 01-24-2016, 04:27 AM
  #9144
howardcano's Avatar
Trader Rating: 37 (100%+)
Try putting a drop of oil where the SPR02 and ST05 go through the "window" in the SPR01. I had a similar problem, where I would press the car down on my setup plate and could both hear and feel something "catching" as the suspension compressed. Some sideways movement of the SPR02 and ST05 is necessary through the SPR01 as the damper rotates, and the oil helps facilitate this movement.
howardcano is offline
Old 01-26-2016, 07:44 AM
  #9145
Default hudy setup caster scales
hi guys
Unfortunately I realized last race that not all Hudy setup systems have the same caster scales...
As you can see on the pic there are narrow and wide caster scales.
The pic shows two setup system from a different batch.
Almost all systems I saw have the narrow scales. The wide scale system was ordered about 9 months ago. I figured out that all new systems should have now the wide scale...
So please check your systems. Most setups you can find (e.g. from Max and Marcel) are with a narrow scale system.
If you adjust 4 degrees with wide scales, it's about 6 degrees with narrow scales
Attached Thumbnails Awesomatix EP Touring Car (A700 Shaft Drive)-img_20160117_164655-640x480-.jpg
Goldstone_RC is offline
Old 02-02-2016, 05:30 AM
  #9146
Hi Guys,
I see that the majority drivers moved over to the A800 cars, but i am in desperate need for a setup for asphalt. The track is medium length, very bumpy and does have off camber turns, with a tight infield. The car is very twitchy and bounces down the straight. I see on some of the setup sheets people are running thick oils in the dampers on bumpy tracks, how would that work as the suspension feels lazy with thick oils. At least the dampers wont leak. I am running a A700 EVO 2 carbon with Team Powers 34 spec tires. Even a decent starting setup, just so the car can soak up the bumps better would also help.
NovakSA is offline
Old 02-02-2016, 08:56 AM
  #9147
Magnet Top's Avatar
Originally Posted by NovakSA
Hi Guys,
What worked very well for bumpy tracks on asphalt is to drill ( enlarge ) the holes in the damper vanes to 1.3 mm ( standard holes are about .9 mm ). And use 3k oil. Of course it's a modification so you'd want an extra set of 4 damper vanes on hand because there is no way to put the "genie back in the bottle", so to speak.
Jake
Magnet Top is offline
Old 02-07-2016, 03:23 PM
  #9148
OVA
OVA's Avatar
Trader Rating: 86 (100%+)
Default D3 damper
Hi
I brought complete set of D3 damper a few years ago and I never got to install them and I wanted to use them for bumpy and low grip outdoor track..question would it be a waste of my time?
my car is A700L with D2 damper...have no D6 on hand ..
OVA is offline
Old 02-07-2016, 06:59 PM
  #9149
hanulec's Avatar
Trader Rating: 28 (100%+)
Originally Posted by OVA
Hi
id say 'it depends'. the d3 dampers could work if it doesn't get too hot. i tried running them at the 2013 roar asphalt nats in florida. this was a mistake. my car would go off during the day, but be amazing in morning/evenings.
hanulec is offline
Old 02-07-2016, 08:12 PM
  #9150
DamageNZ's Avatar
Hey, hopefully this isn;t too silly a question.
I'm having a little trouble with getting a decent damper setting on my A700.
I run on a low grip outdoor asphalt track, and I'm currently running 90.5 Front & 101.7 on the rear - both SRS 1 w soft springs - D2.1 dampers with 500 oil.
Does the higher the number mean softer or firmer suspension?
Car goes really well, but I'm sure I can get a little more speed from it and the dampers are the only thing I havn't really played with yet plus we now have 4 awesomatix cars in our club (3x a700's & 1x a800) so were all keen to figure these out before racing starts in a few weeks time.
Thanks in advance for any help,
Glen
DamageNZ is offline
