Hpi Pro 4
![Default](https://www.rctech.net/forum/images/icons/icon1.gif)
Originally Posted by rc-zombies
the smaller bearing are very fragile...doesn't take much to break them..
stay with the original bearings..
ive been running ceramic 5x8's for awhile now. they havent broken, tho they have degraded more than the stock bearings do in the same amount of time.
they are a fair amount lighter tho.
they have a HUGE disadvantage in that you cannot use the load spacer in between them like you can with the stock 5x10's
![Frown](https://www.rctech.net/forum/classic_images/smilies/frown.gif)
still tho i kinda like them
![Smilie](https://www.rctech.net/forum/classic_images/smilies/smile.gif)
Originally Posted by raptor 700
Another thing my inside tires jwrecks from left to right in a full throttle swepper? Thanks for the info.
i think he ment to put his inside tire jerks left to right when in a full throtal sweeper
Thats exactly what I meant to say. Thanks for the correction.
Is the Pro 4 Hara worth getting over the regular Pro 4? Is it worth the extra hop-ups?
raptor700,
Are you running on a track with a lot of 180's or tight turns?
Also is it foams on carpet or outdoor asphault?
If you are running a spool and there are a lot of tight turns and 180's then you would be much better off with a diff. The issues with the inside tire shaking is from a lack of diff action as the inside tire is rotating the same ammount as the outside one, but is traveling a shorter distance.
Greg
Greg
![Nodding](https://www.rctech.net/forum/classic_images/smilies/nod.gif)
there's a couple of used Hara Pro4's in the forsale section.
yes...worth every penny..
I've currently got 2 Pro4's, one carpet and one asphalt, and I'm trying to decide whether to just sell them and get Hara editions, or simply replace the worn parts and keep racing them....
thanks zombies!
Myself I would just replace the worn parts and get the few Hara hopups. The most expensive thing I guess is the slotted motor mount.... oh wait the shocks are pricey too
![Sweating](https://www.rctech.net/forum/classic_images/smilies/sweat.gif)
Originally Posted by Greg45231
raptor700,
Greg
Greg
[QUOTE=car
trehanks zombies![/QUOTE]
hello,
i was wondering what are the main diffrences between your carpet and
asphalt setups besides foams vs. rubber of coarse?
for example, do you run one ways, diffs, spools, roll center changes, different
chassis or top plate thicknesses etc. thanks
hello,
![Rotating Tire](https://www.rctech.net/forum/classic_images/smilies/tire.gif)
Originally Posted by cartmen34
I'm sure this has been posted already, but speaking from your personal experience, can you elaborate a little on that? What exactly about this car makes it better?
thanks zombies!
thanks zombies!
![Cool](https://www.rctech.net/forum/classic_images/smilies/cool.gif)
Originally Posted by CHRIS CHAVEZ
hello,
chassis or top plate thicknesses etc. thanks![Rotating Tire](https://www.rctech.net/forum/classic_images/smilies/tire.gif)
The asphalt car uses the stock chassis; also with diffs all the way around (It's a tight, low traction track) I've also modified the stock Pro 4 top deck to match the Hara edition.
The carpet car uses a 3mm BMI main chassis & 3mm top plate; diffs all the way around. I've not made any other parts changes to the car. Just messed around with the setup a little.
What is the difference between the hara and the 2005 edition? And cemirca diff balls worth it and what is the best company to buy from? Can someone post a template of the hara top deck? Thanks everyone.
