Hpi Pro 4
Originally Posted by Gary Fliegel
Alright guys, I am looking at buying a Pro 4, standard kit, new in box. What are the absolute needed extras for this car? It will be run on carpet, so I know I will be chasing down a front diff for it. What are the recommended hop ups and changes I need for the car? Thanks.
or you could buy my Hara edition that comes with a 2mm, 2.5mm, 3mm chassis and 2mm. 2.25mm, 2.5mm upperdecks...
but I haven't quite decided to part with it yet...
Actually I have the standard kit and I am very fast with it without the stiffer chassis. All you have to do is find the right setup and I can help you out with that if you would like.
pro 4
hi i was wondering if any one could give me a set up for rubber on concreate and very little grip
anyhelp would be good
set-up
tedehI....do you mind laying out a set-up for carpet w/ foams. i have the basics pretty much dailed for my track..........plaid fronts and purple rears! LOL.
No Problem
Front
70 wt associated oil with associated white springs 1.3mm 2 hole pistons, no swaybar, 2nd to outer hole on shock tower and outer hole on A-arm, and Parma Plaids
Rear
70 wt associated oil with associated purple springs 1.3mm 2 hole pistons, no swaybar, stock upper shock location on shock tower, and middle hole on a arm, also Parma Purples
Stock Chassis 2.5mm and stock upperdeck also 2.5mm? No center post and a droop of about 6 front 6 rear with ride height at just above 4.5mm
Hope This Helps
Front
Rear
Hope This Helps
I was considering purchasing the BMI chassis for carpet, is this a good investment or is there another aftermarket 3mm chassis out there!
I have the PRP 3mm chassis on my car.
I bought the BMI kit. 3mm chassis, top deck and shock towers.
I personally wouldn't recommend anything else!!
BMI makes awesome products.
JW- are the shock towers lowered? and what colour did you get?
Yep, it has the lowered shock towers, and it's the standard graphite color.
Originally Posted by MikeR
Yep, sounds like a little chemical reaction is going on from all the heat
AMGRacer-That's a good observation. That might mean either the Cyclone is generating more grip and therefore heating up the tires a lot more OR you just drive much smoother than your pal
On another note I put the Cyclone setup by Hara for Yatabe Arena on my Pro 4. It works a TREAT. I think the cyclone and pro 4 are very similar in performance. The cyclone feels like it has more turn in, but the area where it is better is on power. Corner speed is not that much different from what I can see, but mayby it is just my track.................
So I'm hearing a lot of positive things about the BMI parts for the Pro 4, but I can't find their website. Can someone throw a dog a bone?
www.bmiracing.com
Selling my BMI Pro 4. If interested let me know.
So I am getting out of 4wd electric sedans and want to try something new. I have a BMI Pro 4 setup with lots of extra part for sale in the For Sale/Trade Forum. Here is a link: http://www.rctech.net/forum/showthre...69#post1938969
If interested PM me.
