Hpi Pro 4
![Default](https://www.rctech.net/forum/images/icons/icon1.gif)
Hey,
Anyone got a setup they could post for low-medium traction carpet track w/rubber tires (CS-22/27)? I already d/led the ones off HPI and got one of the local fast guy's setups, just curious to see what others are running
does the front imput shaft on a Pro 4 move in a crash? Seems to be a problem with my TC4 in a hard impact. Is this car good for carpet racing? I read mixed reviews about it. I'm also thinking of a BMI chassis to go with it.
i race carpet and have a bmi. This car works just fine for me. It all depends really on what you prefer. I like the 3mm lower deck and the thickness of the upper deck...less flex.
Hey does anyone know where to get the purple aluminium screw? thanks in advance
www.fastener-express.com
Originally posted by BlackKat
Hey,
Hey,
The thing I noticed on the DHI and other setup on the HPI site was in one race they ran a one-way and the other a spool I tried a one-way. Not good for me, probably because I'm to use to throwing the car into the corner with foam tires on it. I have not tried a spool yet.
take care
john
Originally posted by TFR
Didn't you get a PM from me about purple screws?
may i know where you get o-ring for the body post? thanks
hey tfr what bumper are you using?
![](http://www.realrc.net/images/news/hpi_72044.jpg)
Is it ok to leave my dogbones slightly twisted... I noticed it when my font dogbones would slightly move up and down when i spin them.
How can I setup my car to run on ashalt with 3mm lower deck or should I give up and get the 2mm one instead?
![Smilie](https://www.rctech.net/forum/classic_images/smilies/smile.gif)
Can someone point me to the page # (from this PRO 4 thread) pertaining to the HPI springs rate in LBS/Inch rate......I knew someone listed that more then 1 times, but with 300 something pages to search.....it is almost impossible for me to do it with very limited computer knowledge....
I do not have HPI springs set, but do have AE and LOSI springs set, just want to get some reference....thanks.
