Hpi Pro 4
#6316
![Default](https://www.rctech.net/forum/images/icons/icon1.gif)
Originally posted by Rookie Solara
Did you know that we converted EUGE to be a PRO 4 owner as well....? And Nexus is thinking HARD (very hard) to get 1 as well....I think the ROAR NATIONAL champion does help them to made their decision..........it does on me.
Man, i just went through the last 60 or 70 pages of this thread........whew......
#6317
#6318
Originally posted by CraigH
Man take a break, your eyes are going to be fried.
I started reading at page 150 and I'm all caught up. yikes.
#6319
Originally posted by kewdawg
robk, What were your droop settings?
And ackerman setting?...
And chassis / top deck type & thickness?...
And body / wing?...
And type of foams used?....
Ya' know what?... How about attaching one of those cool Hpi interactive set-up sheets, Please?
#6320
*2mm over ride height in front, 3mm over ride ht. in rear
And rear toe block?..
*2.0 rear toe
*stock
*stock.
And body / wing?...
*Parma Alfa, though maybe a Mazda could be better, I think Kevin K ran that
*Eagle Racing, basically gas car rubber
If I can figure it out I'll do it later
*2.0 rear toe
*stock
*stock.
And body / wing?...
#6322
What page is that on
![Laughing](https://www.rctech.net/forum/classic_images/smilies/laugh2.gif)
#6323
Hi Thad
Started changing car over to you latest setup sheet last night. Though will have to make some changes like a bit more ride height as the track is fairly bumpy. Also I have heavier shock oil in at the moment and not 100% sure what pistons...
Anyhow, there is no figure in the box for the height of spacers under the rear upper camber link on the back gearbox,you know the purple ones that go under the ball stud... does that mean there should be none? (there is no 0mm or anything so i dont know if it has just been missed out)
Thanks for the help, looking forward to trying this setup out on the weekend :nod
#6325
Originally posted by rc-zombies
you read all the pages...wow...
you like my BBQ'd diff gear...
holey smoking diff gears.....
#6329
OMG!! How did u do that??
I had a similar result with a belt pulley/diff on my TA04 when I jumped it over a board and landed square on the back wheels with full throttle and killed the belt, and stupidly kept running and the belt melted the pulley :S
#6330
![Frown](https://www.rctech.net/forum/classic_images/smilies/frown.gif)
