Like Tree87Likes
Hpi Pro 4
Old 06-16-2004, 01:00 PM
  #5581
speedxl's Avatar
tony I didnt get one!
speedxl is offline
Old 06-16-2004, 02:29 PM
  #5582
Anybody noticed that the pro4 is lacking forward traction? it handles great, but im always getting beaten off the line
Mercury Racer
Make sure your diffs are tight enough because if they are slipping you car will be slow off hte line
Steve B is offline
Old 06-16-2004, 02:32 PM
  #5583
Default PARTS ARE IN!!!!!!!!!!!!!!
My local shop got my arms and hubs in today that have been on backorder so I would say that if I can get parts in BF Egypt then they will be available everywhere!!! Now there are no excuses to get a great car and have fun racing.
Doug Gaut is offline
Old 06-16-2004, 05:17 PM
  #5584
Default Re: tc3 vs. pro4
I have the same problem. The Pro 4 seems to lack some steering compared to the TC3 and Yokomo that I had before. My setup is very much based on the stock setup as per the manual.
Can it be that the rear toe is too much? (3 degree) Anybody has the same problem with lack of steering here?
Originally posted by punkboy
im still new w/ my pro 4. i would like to get alot more steering in it, and i have 2 find a good rollout 4 my track. i had a tc3, and it was perdy good, but it too needed steering on that track. my lap times are about the same with both cars now, and i know what needs to be fixed on the pro 4. i think it was a little harder with the tc3 cuz it wasnt "straight". the pro 4 seems to be a little straighter to me, dont know why, or how, it just does. that is the same with all the 4's i have driven and seen. infact, sport let me run his, and he's why i bought the dang car...i really hate that guy. j/p
me personally, i would go with the hpi, especially after they have parts, and tuning options out for it.
tslim is offline
Old 06-16-2004, 06:25 PM
  #5585
rc_square24's Avatar
what springs and oil wt are recomended to start on foam-carpet setup?
preferebly HPI springs...
thanks
rc_square24 is offline
Old 06-16-2004, 06:57 PM
  #5586
hey, ive run my pro 4 2 race days now, and when i 1st started with a 19t, it was okay...then it started to feel tweaked, still with 19t. checked the tweak, and it was a little off, so i corrected it, and the car felt a little bit better. i took the car home after day 1, and rebuilt it, making sure the chassis was straight, and i had no tweak. when i raced it again, it was all over the place only on left turns...so i checked the chassis, and tweak again...it was straight...the car was still horrible tho. i thought maybe it was a weight issue, so i added about 2 ounces of weight to the right side of the car. i think it helped a little bit, but the car is still horribly lose coming out of left turns.
I think what started the off balance of the car was a hit that i took in practice on day one. it was brutal enough to take a chunk out of the graphite on the battery braces. i am about to check for any bent parts, and maybe change the arms, but what i am wondering, is if anyone had any ideas on if it was the hit that i took, or if i should keep looking at the weight issue...
thanks for any, and all help
punkboy is offline
Old 06-16-2004, 07:00 PM
  #5587
tslim, what tires are you running on your car? i had dbl purp fronts, and purp rears. i changed to plaid all the way around, and the car felt a little better
punkboy is offline
Old 06-16-2004, 08:22 PM
  #5588
Pit-racer's Avatar
Originally posted by Pit-racer
I will be getting a Pro4 soon. What are the parts that are a must have for asphalt racing and also some carpet.
Anyone?
Pit-racer is offline
Old 06-16-2004, 08:30 PM
  #5589
the right tires
craziracer is offline
Old 06-16-2004, 09:49 PM
  #5590
rc-zombies's Avatar
Default Re: Re: tc3 vs. pro4
nope... I think the Pro4 has more steeing than the TC3 or SD...both of which I formerly owned.
rc-zombies is offline
Old 06-16-2004, 09:52 PM
  #5591
rc-zombies's Avatar
Default HEATSINK MOTOR MOUNT
just got mine installed today...installing the motor is no problem....but if you have larger electronics you might... right now I have the Fut S9450 servo, Fut HRS receiver, and Keyence Extreme Zero. and that is no tiny speedo....
The only problem I have is tightening the pinion screw. You will almost need a ball hex driver to secure the set screw. ..
otherwise it looks great and should improve motor cooling...
Old 06-16-2004, 10:25 PM
  #5592
Entropy's Avatar
Default Re: HEATSINK MOTOR MOUNT
An alternative is the Square heatsink motor mount, which is basically a finned version of the HPI one without the closed end and is probably lighter.
Entropy is offline
Old 06-16-2004, 10:43 PM
  #5593
Eirik's Avatar
Hello tslim,
For more steering I would do the following:
#1 Less Castor, I went from 4deg to 2deg and the laptimes was faster
#2 Less rear toe inn will make a difference for sure, less turn inn, but more on exit.
#3 Stiffer rear springs! If you use the stock Silver ones then go to the stock gold ones in the back, way more steering and cornerspeed!!
punkboy,
Use more travel in the left rear tire! If you use 5mm on the dropp gauge, then go to 4mm on the left rear tire. That should cure your problem!
Regards,
Eirik Andreassen
Eirik is offline
Old 06-16-2004, 11:17 PM
  #5594
crazy4rc's Avatar
Default Rear Differential Slipping
I got tired with my slipping diffs. i changed the diff bolt to TC3 (6575) adn use TC3 spring (6582). So far so good, no sign of slip after 3 long runs. Also I changed my front one way diffs to 2 way stock. The car handles a lot better in the corners .
crazy4rc is offline
Old 06-16-2004, 11:37 PM
  #5595
Skill's Avatar
You have to position the motor so that the slot where the pinion screws onto is facing one of the slots of the motor mount. In other words, you can tighten it easily if you put the driver in one of the slots and line up the grub screw with that.
If you have understeer theres a couple of things you can do:
If on smooth surface lower the suspension mounts right down so they are against the chassis with no spacers (note: this changes the droop so you'll have to change that too)
Run with rear sway bar and no front sway bar.
Lay down the front shocks
Stand up the rear shocks.
Skill is offline
