Hpi Pro 4
#2956
![Default](https://www.rctech.net/forum/images/icons/icon1.gif)
Originally posted by rc-zombies
Pretty much build per instructions... the shocks are self bleeding so majority of the time all the shock will feel the same. After you build do the rebound test...2 at a time...compress the shocks without any springs...and they should fully extend approx the same time....
50wt oil...if our running outdoors on asphalt you may want to drop it down to 40F / 30R depending on your track...
What would I look for if the shocks do not fully exend at the same time? My shocks seem to be full of oil with no bubbles.
Also, do any other manufacurers spring work on the Pro4? For example, Associated makes a set that has 6-7 different spring rates. Will these springs work on the Pro4?
#2957
#2958
![Big Grin](https://www.rctech.net/forum/classic_images/smilies/biggrin.gif)
I think the AE shocks will work...I don't have any so I can't confirm... I know other racers here have tried it...
#2963
#2964
![](https://www.rctech.net/forum/rctechv3/special/techelite_alt1.gif)
Guys;
Well I FINALLY found some time to work some more on this Car.
I am really impressed with the Hinge Pin mounting system. What an improvement over anything else I've ever built Electric or Nitro. No slop what-so-ever, and it looks like it will stay that way for many months of racing.
Thanks for the tip on buying a 2mm Driver. This has made installing the screws so far a breeze.
One question:
The kit supplied Shock Springs are very soft. I have the all of the HPI 27mm Springs. Any recommendations on a Spring starting point for outdoor Asphalt?
Thanks,
Steven
One question:
Thanks,
Steven
#2965
Originally posted by popsracer
Guys;
One question:
Thanks,
Steven
Guys;
One question:
Thanks,
Steven
the stock springs are 25mm high.. 27mm might fit...
#2966
Anyone intersted in a stock/foam tire set up I posted one on the BMI thread.
#2968
Originally posted by RandyB
hey rob what are the bsr tires?
#2969
RandyB,
Right now BSR is buying there rim directly from Jaco. They get their foam from the same source, but glue them up themselves. Basically a Jaco right now until Foister gets the rim done. They are nice tires.
#2970
I know instructions say to glue inner plastic ring on rear diff, but why? I have run mine at 4 races and have not felt any thing bad developing from not gluing. Gluing it in seems to be asking for trouble with bad alignment. Any info would be appreciated.
