Schumacher MI9
#421
![Default](https://www.rctech.net/forum/images/icons/icon1.gif)
A good night of USGT tuning with some friends and a lot of trash talking. (Mines is the blue Mugen) ![Big Grin](https://www.rctech.net/forum/classic_images/smilies/biggrin.gif)
![](https://cimg2.ibsrv.net/gimg/www.rctech.net-vbulletin/2000x1504/20240620_230821_9cb5c69e1bb827009b41d9364c16ff34fe04505e.jpg)
#422
The build has started - I went straight to the possibly.painful stuff as I wanted to be sure whether I was already equipped, since the coreRC pliers are OOS pretty much everywhere in the world....I'm glad I had these babies handy from my 8th IC OR (long gone) days. Possibly an alternative for you guys too.
![](https://cimg7.ibsrv.net/gimg/www.rctech.net-vbulletin/1460x2000/img_20240620_221305452_hdr_2_463d6c611b4ed4b0e84813609efdd0177df70bcf.jpg)
#423
Mine is the one in the middle. The one with the battery cables over the top, which i wouldn't have it any other way. After running 4 battery packs i lost an o-ring on the rear wishbone assy socket. Not sure how one bearing stayed on but lost both e-clips and one bearing. I can't believe i found the bearing. Glad you get extra e-clips with the kit. Does anybody have a better option or idea for rear body posts position. They are to wide for the body i run.
#424
![Smilie](https://www.rctech.net/forum/classic_images/smilies/smile.gif)
#425
#426
![](https://cimg3.ibsrv.net/gimg/www.rctech.net-vbulletin/1480x2000/img_5321_22d3cb7811ac3263dc5bc9d47fcd5a635200d2e3.jpeg)
![](https://cimg6.ibsrv.net/gimg/www.rctech.net-vbulletin/2000x1504/img_5313_42deb2f65469823bf278e1bcdaa9e4b183cfe3a6.jpeg)
I completed mine last night and try to mount my latest painting body shell but it didn’t go well.
The width of the front body post is the same as Xray X4 but it seems a little bit more upfront thus I made the whole around 66mm away from the window and the body shell was way to behind than what it was supposed to be.
Sadly I had to throw away the beautiful body shell. 😥
#427
#428
I see it's not always easy to see tell if a body will work until you buy it. The body posts in the rear are the standard vertical posts but they line up on the edge of the humps. Very wide position on the rear body posts of 124mm.
![](https://cimg7.ibsrv.net/gimg/www.rctech.net-vbulletin/2000x1504/img_5386_copy_d391a0886f5e42eb3980311213e335e6dee87dd2.jpg)
#430
Or you can use a magnetic body post marker kit. With the magnets you can see where the posts are and measure and mark the right distance. Also U4806 is useful to mark the wheel arches.
If you drilled the holes wrong you could use uv glue to glue some lexan over the inside and make new holes and use the body for practice.
#431
But it worked so it was worth it.
Vertical mounts are better anyway, the horizontal posts just became popular because its easier to mount bodies.
There is a def difference in when to use them though.
#432
Sorry i edited my post, i meant to say purchase not practice. It looks like i will try the magnetic route in the rear because i see no other option if i use the body i have already purchased and hydrodipped backwards. Do i still aslo need some sort of post to go thru the body when using maginets. I can't see them holding up when hitting a wall. A picture would be nice if you have one.
#433
Double and triple check the positioning though before reaming, it's still easy to get it wrong even when using the magnetic tool.
#434
Now i get it. I thought the you meant using a maginet body post to hold the body in the rear during a race instead of the body clips. I plan on getting magnetic body posts, but not sure this is the best route for racing, but they look awful darn cool.
![](https://cimg2.ibsrv.net/gimg/www.rctech.net-vbulletin/492x497/mag_body_posts_fba603dc08723c00b031a8d1b8ab3d034d851abf.jpg)
