TRF211XM
#121
![Default](https://www.rctech.net/forum/images/icons/icon1.gif)
I am driving the 201XMW at the moment. I have a 211XM but I plan to build it up for next year's indoor season. But I have been driving 201s of all types for 5+ years and I won't try something else. Other drivers have let me drive their B5s and 22s;I don't really notice a difference. If set them up properly, any brand will work just fine. But, for me, it's all about the highest quality and being different from the rest of the pack. And without a doubt in my mind, Tamiya is quality. But you will pay a premium for that so be aware. There are ways to help alleviate the higher cost of owning Tamiya cars but it takes research and patience. And typically the resale value is terrible so I wouldn't recommend this route if you are known to jump around alot.
I don't regret it one bit. I catch a lot of jabs for being different at the track, but now it's become fun banter.
Hopefully, this helps but if you want to know if the car is capable of competition; yes, it is.
#122
I guess I just wanted a front carbon shock stay, to match the rear shock stay.
As for the kit, I've found the front wheels required for the 211XM, but which rear wheels do I need for running the stock setup without hexes?
#123
![Cool](https://www.rctech.net/forum/classic_images/smilies/cool.gif)
#124
Take it from me, if you are buying this brand new for the first time. ....NOW is the time to use rear hex wheels.I made the mistake of using the rear pin wheels. Then I bought my son a Kyosho. The other son and daughter got a TC02. They were able to swap out rear wheels/tires without hesitation. By that time I had a few sets for my Tamiya but was unable to easily use the hex sets when I went racing alone. About a year ago, I put my original 201 in the 17.5 class and it is using the remaining pin wheels and tires until I wear them out. Then I will convert it to hex like my 201XMW and db01.
#125
#127
As for your question, I haven't raced in a while because summer has been busy. But I have plans to get back to using my original 201 in Stock class and the 211XM in modified this winter
#128
I did up until a few weeks ago, when I won an Associated B5m Factory Lite in a raffle, & since I didn't have much to do, I went ahead & built it. And I have to admit, while I don't think it accelerates any better(& it's DEFNITELY not lighter than my 211XM, with the same battery & electronics it weighs about 1530g, while my 211 without any extra weights is about 1470g), it does handle every bit as well, & may even feel more consistent than my 211. For dirt, I'm thinking I'll keep using the B5m, but reserve the 211XM for carpet & backup duty....
#129
I did up until a few weeks ago, when I won an Associated B5m Factory Lite in a raffle, & since I didn't have much to do, I went ahead & built it. And I have to admit, while I don't think it accelerates any better(& it's DEFNITELY not lighter than my 211XM, with the same battery & electronics it weighs about 1530g, while my 211 without any extra weights is about 1470g), it does handle every bit as well, & may even feel more consistent than my 211. For dirt, I'm thinking I'll keep using the B5m, but reserve the 211XM for carpet & backup duty....![Cool](https://www.rctech.net/forum/classic_images/smilies/cool.gif)
#130
i still racing 211xm
in europe have many dirt tracks, low to high grip
i run shorty, with 55g under battery, B5 front arms (stiffer than original) and Bmax front with hex.
overal very balanced car, easy to drive anywhere
#131
I can't get hold of the proper spring kits for the big bores that come with the 211XM - can anyone recommend a kit from an alternative manufacturer with a part number of poss?
Many thanks!
Many thanks!
#132
#133
They're most often prices above Kysho, Yokomo and frankly every off-road car out there but with little support behind the products.
