New Schumacher KF2
#47
![Default](https://www.rctech.net/forum/images/icons/icon1.gif)
One setup aspect I didn't quite figure out.
The front hub carrier position, whether it is high or low, makes what sort of difference?
#50
I contacted Schumacher direct but have not yet had a response. Any advice would be appreciated?
#52
There is one thing I could not visualize...
For this car, you can set 2.5 or 3 degrees rear toe-in.
How is the 2.5 degrees set, with the toe blocks facing in?
#53
Because the pinholes are slightly offset to the mounting holes.
That makes a difference of about 0,5 mm or 0,5° when swapped.
Cruise
Cruise
#54
anyone planning on running the KF2 at motorama? i shook down my KR cars yesterday and will try to run this new KF2 prior to the event. any starting setup advice would be helpful.
in particular, i think i need to get my hands on a ball diff prior to the event. KF setups from Tom C and Carson W both listed ball diffs. anyone know where i can get a U4199 diff?
#57
built the rear end tonight. reversed the arms. rear hubs fwd. shocks on back end. mounted inner arm position, and leaned in at top. 3mm anti-squat. 2mm on inner ball link.
put 7K asc diff fluid (not sure if there is a better option/opinion until i can get a ball diff).
#60
U3852
U3853
U3854
U3855
U4196
2.5mm diff balls (carbide or ceramic) I personally prefer carbide at U2459
U3140
U1954 (Optional)
It is a K1 diff after all, so look at this:
http://www.racing-cars.com/images/Te...1_exploded.pdf
