TLR 22-4 THREAD
#2761
![Default](https://www.rctech.net/forum/images/icons/icon1.gif)
Is there some sort of servo saver built in to the steering, or should i get one? I noticed the build seem to have the servo horn directly on the servo.
#2762
check the TLR Youtube channel for their 22 diff break in video with Matt Castelano. you use the same steps for the 22-4 diffs.
start at the 9 minute mark for break in method.... this will help build diffs that last a long time and work for a while with little maintenance.
http://www.youtube.com/watch?v=EToj2yX76NU
#2764
Went to change my broken and arm and discovered I only had a half of a hinge pin. This blows. They appear to be out of stock at horizon and the only set I could find was eBay. $17.99 plus shipping and HOPING it's here by Wednesday. I would think that an SCTE style pin would work with e-clips or nuts on either end instead, something similar to the make shift pins some guys are making.
Edit: just pulled the pins out of 22T. Same thing it appears. Just ordered 5 sets of them on eBay. Part number TLR6079. Couldn't find them on horizons website tho, maybe gonna be discontinued??
#2765
#2768
In all.. I think I had the slipper to tight and may have been able to get more wear out of it. On power I doubt it hurts really, its on braking they get hit pretty hard. I do however run my brakes pretty soft. the slipper is a bit tricky been its not visible.
So round 2 I will loosen the slipper and throw a bit more motor at it if needed. I rebuilt the diffs and put a complete new set of belts on it. For sure the rear belt was still great. The center was iffy (due to the darkness) so I will use those up later. The stock belt settings are fine both center and rear belts were still snug. Not even a fray in either one. Inspecting the broken belt I could see strands of what were wire or Kevlar? So the belts look pretty tough.
Now be prepared for the task of getting to the belts. I was having flash backs from the XX4 days..LOL. It was a bummer till I started putting it back together. Zipp and done. Tear down was slow but next time I will have it down on how and what to do so its not that bad at all. I use a small battery drill and makes it less stressful though. I studied the manual and kept it handy for putting it back together. It was clean as a whistle in the belt compartments so they are sealed real well.
Personally I would't mind a belt a month this kit is dialed.....
![Nodding](https://www.rctech.net/forum/classic_images/smilies/nod.gif)
#2769
#2770
they new do an on road gear diff
#2773
#2774
Yeah no ball diffs was a big turn off for me too. Kit looks sweet just not for me. I was hope ing for a mini scte oh well
#2775
This happened last night from rolling after I landed the buggy a little bit too far off the jump
![](http://i911.photobucket.com/albums/ac314/frozencone/20140209_203804.jpg)
![](http://i911.photobucket.com/albums/ac314/frozencone/20140209_203749.jpg)
I hope this is not another issue with the material. First I thought I broke the rim but when the marshal pick up pieces of what left, it appear to be the tip of the drive shaft where thread are being cut for the wheel lock nut. I'm a bit frustrate now that I have to order drive shaft set from Amain again and hopefully the shipment will arive before Sunday because I have a race to attend and I really don't want to miss running my Losi on this race. Hate to have to run Durango for our first race of this season.
![Frown](https://www.rctech.net/forum/classic_images/smilies/frown.gif)
