TLR 22-4 THREAD
#2162
![Default](https://www.rctech.net/forum/images/icons/icon1.gif)
Casper???!!!!!!! ( or anyone else) When I built mine this week I'm having an issue with the kit shock caps leaking. Used all kit parts O rings and such. When cycling the pistons I still get residual fluid to seep out. Do the team Drivers use the cut shock diaphram/ O rings to sovle this? That what Im debating to do. The kit Oring for the cap just doesnt appear to be thick and large enough for the cap.
#2163
#2164
Thanks. It was a ton of fun. I finally got into a rhythm and was having a great time making my way through the fields. I bumped up to about where I expected to be but I will admit this was way more fun!
Yeah you should have an o-ring that stretched over the cap threads on the shock body. This will seal the cap at the base of the treads. Never had an issue at all with the caps sealing there. The cut bladders will eventually suck into the body of the shock after a few uses.
The cap ring should go on like explained in this blog post.
http://losiracing.blogspot.com/2012/...p-o-rings.html
#2165
First run with mine last night. Small, bumpy, med/low bite track. Kit setup was too stiff on oil. Went down to 25 rear, 27.5 front. Changed the front pistons to 3 hole 1.4. Yellow rear sway bar and the Phend front camber setup. Car felt okay, still had a problem with the car wanting to barrel roll after dowsiding into 45's to180's. Installed the clicker and the car came to life! I think it was the drag of the front end full time drive that caused that issue.
#2166
I found this one on eBay and bought it
http://m.ebay.com/itm/300955989601?nav=SEARCH&sbk=1
It's a v1, but hey, it was only $80, NIP!
#2167
I've crashed the ish out of mine already.
That's how I roll.
10 to 12 packs thru it and one broken part.
A front arm BUT I did try to put it into an end of a PVC pipe.
It didn't fit even at full speed.
Only one arm?
No broken tower?
No bent hinge pins?
No broken bulkhead?
It's pretty damn tough.
That's how I roll.
Only one arm?
No broken tower?
No bent hinge pins?
No broken bulkhead?
#2168
![Smile](https://www.rctech.net/forum/images/icons/icon7.gif)
Thanks all.
#2169
23T
The Dynamite DPS 5.5T is working great for many of the guys on our team as they weight for Orion Motors.
#2170
stock kit oil is 32.5 right?
#2172
TLRacing
#2173
I started with the Dunford set up. I really like the car. Really easy to drive. But I have a bad push. We run on a slick wet clay tight track. Im getting killed in the tight 180's. Any suggestions?
#2175
These aren't available in the US yet. The Vortex Pro and VST 5.5T motors barely sold at all, so when the Orion VST2 Pros were brought in, the 5.5T was not. It is in the process of getting added to the line up, but will likely be a few months.
