TLR 22-4 THREAD
#2013
![Default](https://www.rctech.net/forum/images/icons/icon1.gif)
Yup rear end is built and perfect, I know what pulley goes front and rear, rear pulley has 2 belt guides, front pulley has only one on the right side of the pulley, so if you look you will see that IS the front pulley and is the wrong pitch. My front pulley and rear pulley are the same course pitch.
And other than the pitch, that does look like a front pulley.
Maybe a future upgrade accidentally got in your box?!?
Hmmm..
I'm curious what the Team guys tell you.
#2015
Btw, it's a rear pulley with the sonic welded flange missing.
#2016
#2017
pondered this just now.... in regards to 1/10 scale
TLR is 2 for 2 on exceptional kits (22 2.0 and 22-4)
TLR is zero for 2 on kit release bodies. Thank god for aftermarket and the smarter people at TLR who come out with better bodies later on.
by the way. the stock 22 2.0 body does wonders for holding my door open thanks
![Smilie](https://www.rctech.net/forum/classic_images/smilies/smile.gif)
#2021
Hello, I am looking for some guidance on the clicker or full time 4wd settings for the front end. I mainly run on an out door - med bite track blue grooved mostly warm out ..... Would you recommend the front clicker set up or running locked down ? Also, I see some mention of certain peoples setup's , I did not see any setup sheets on the website, are they on here somewhere ? I am running the base setup right now and it felt pretty good, however I just want to see what some of the Pro drivers are using as a comparison
#2023
nice truck
