TLR 22-4 THREAD
#1996
![Default](https://www.rctech.net/forum/images/icons/icon1.gif)
Hi. Have you gotten a chance to see if the R614fs or R603fs fits?
Has anyone been successful getting a Futaba R603 receiver in this car? I have tried mounting it ever way I can think of and it always hits the body (about 1/8" pr so from being able to install the body clip. This is trying to install it on the right side of the car in the designated place. Any help would be great. I may try to buy one of the newer R614 receivers but they are not that much smaller but they are a little bit.
#1997
#1998
#1999
Here's one with the belt around the front pulley
#2001
Yup rear end is built and perfect, I know what pulley goes front and rear, rear pulley has 2 belt guides, front pulley has only one on the right side of the pulley, so if you look you will see that IS the front pulley and is the wrong pitch. My front pulley and rear pulley are the same course pitch.
#2002
#2003
#2005
Double Dot is a special MC compound they have for team drivers (I think) and it was used at Reedy. It works better than regular MC and wears quicker too. I got a set of regular MC Ion's as well by accident. Gold Dirt Webs were WAY better than those (IMO) and still lasted longer.
#2006
I am running the Dunford set up and have no problem getting the right ride height. I order all my extra parts and the parts need for the set up frpm Horizon and had them in a day!.
I am running the rear sway bar and the 1.5 hexs.
Running a 8.5 with my Tekin RS and had to add a fan. Running AKA Typo's all the way around with red foams and the car was hooked up at IERC. I did break my front arm but was totaly at fault as I put this car though the ringer!!!
Build was super easy. I need a little help setting the slipper but other that that great ride. I did not get any pics with tires mounted.
#2008
We apologize for your kit missing the front diff pulley. Please call Horizon Hobby support and they will send you the correct pulley. Tell them you will need TLR232024 (Drive & Differential Pulley Set).
#2009
The car looks like it squats more than it actually does due to the shape of the body. What set up are you running currently?
If you really cant get it, take an .050 from the opposite side and tap it out.
I haven't had any issues getting correct ride height on multiple cars now. This should not be an issue.
I ended up taking a hammer and punch to the roll pin until I could get a firm grip with pliers. Luckily I had more pins to replace the original one.
Can't wait to try your ocrc setup on my 22-4 but I have to wait on the rear 1.5 hexes and sway bars.
