Tekno SCT410 Thread
![Default](https://www.rctech.net/forum/images/icons/icon1.gif)
Im building my truck and was wondering if any one else had to ream the arms and tap all the screw holes. Its no big deal just wondering if all the kits are this "tight". Thanks
I have now built 4 sct/eb's and have never had to tap screw holes but yes it is definitely recommended to ream the arms although I did not on my first truck and it loosened up after a few race weekends.
What bodies besides the j concepts titan have people had good luck with?
yup, it was this listing I bought:
For the price, I couldn't pass it up. She was going to start with my RC10B4.X that had the front end "RPM'd", but, this worked out better.
Now the old man needs a new body, I think my flotek is done.
Anyone got a recommendation on any of the proline bodies outside of that EVO one?
thanks for the heads up. I ordered the Jconcepts Nissan Titan body, regular thickness.
Right now, I am thinking about buying some more wheels, debating between AKA, Avid, or some Proline F11s.
Any recent opinions on the Proline's F11s versus Avids?
As for tapping th escrew holes, there's not really a need for that, they tend to tap themselve as you use the cap screws and button head screws. The link arms as well.
I would recommend staying away from the Avid wheels...I rounded out the hexes in those on a few separate occasions...Never had a problem with any other brands.
I have a set of the Proline F11s and AKA Enduros mounted to them. I have used them all summer and have been great. I plan on buying another set this week since indoor season will be starting soon
As for the Arms, yea that's kindof typical for most kits. When I had my SCTE and my D8, I would ream the arms so they move freely during suspension travel.
![Big Grin](https://www.rctech.net/forum/classic_images/smilies/biggrin.gif)
I've had pretty good luck with the standard pro-line flotek. But did need to cut the extra bit of trim off the wheel wells to get good clearance. The standard JC hiflow was ok, but it broke in half on me pretty quick, truck is too heavy for it to last with all the cutout used.
I've wanted to try other bodies but shipping two day compared to the other stuff I was getting both times made me go to LHS instead and selection was more limited.
Anyone try the Pro-line EVO on this truck?
I was going to try the EVO, but I didn't find it on amain at all and other places are showing october to getting it in.
Maintenance question for everyone, I noticed that when working on my daughter's vehicle to get it setup prior to her first race, I noticed that when tigthening down the front top plate that goes on top of the steering posts, if I went too far I got binding in the steering rack.
I never noticed this before on my EB48 or my SCT410.
I plan to have her disassemble and reassemble her vehicle so she can get used to working on it some so want to address that as well.
Anything in particular I should look for?
3 or 4 mm reamer for the arms?
I started out with 2 shims on the pinion on the inside of housing and it did not sound smooth, so went to 1 and then none and put 2 on the outside to close the space between bearing and coupler. Does that not sound right? and what do you mean by backlash?
also, with the new angled rear housing I did not have to use any shims on the left and right side of housing, it was a great fit.
When he says "backlash" I believe he's referring to the amount of play between the ring gear and the diff pinion. My drivetrain spun very smoothly and seemed much quieter.
