Tekno SCT410 Thread
![Default](https://www.rctech.net/forum/images/icons/icon1.gif)
Run stock shock locations too. Upper outside, lower middle as a start.
Thanks for the tips, I am setting it up like Austin Blair's setup for an outdoor track.
His sheet has similar traction characteristics
Use profile 3, double check that your set to 4 pole and that your voltage cutoff is atleast 3.1V per cell. If you are running on a high bite track start around 70% on the throttle punch, and PWM at 24000. BE SURE your drag brake is disabled or you will really see some nose down issues. I'd start with 100% brake and dial it out with your radio. PWM on brake 12000, but don't be afraid to go up from there if you don't think that it's smooth enough.
If you have any questions contact Nick at Viper. He's a super awesome guy, and he has it crap together.
Those were the settings that I started with, but I'm running the 4300 Pro4 HD. I can grab my truck at lunch along with my proguage and PM you the settings that I'm using. I know they work with the 4600 as a good buddy of mine is using that same combo, and it's more than capable. Good luck.
Looks like I am going to be in the market for a new body. So, what do people suggested that:
1. Durable, must be Durable first and foremost
2. Cutouts prevalent everywhere
Also, what bodies are precut, just not drilled that people recommend?
+1 great info. Love this thread for that!
Dear Tekno,
Can you send me Austin's Truck from the Nats a few weeks ago so I can post his setup and then send it back to you?![Laughing](https://www.rctech.net/forum/classic_images/smilies/laugh2.gif)
I was looking at the site, and those setups are pretty outdated. Any chance we can get those posted?
Thanks guys!
Thanks guys!
For the whole losi hi flow precut body, based on reviews on Amain it seems its thin in areas. Is this still a problem or what it just an issue back when that all was posted?
Will give the other bodies a look too.
My favorite features I spot on that body are the big flat areas around the body posts. I hate when there is a molded roll bar right next to the body post making it impossible to get a body clip in easily.
+1! I like the looks of it as well- different.
Thanks for the input Grimm. I've had a rough time getting my Vtx8/vst4.5xl set up. That's why I got the pro4. I read some posts where people were having a a hard time getting the vtx8 and pro4 to work together.
that body would look a lot better with a new paint job, either way it looks good, so they painted the outside on the back to get the flat black, correct?, I might have to do that
Building my kit right now, the rear camber links first of all are really hard to get the ends on, now that I have them on all the way down (no threads showing, I can tell its going to have a good amount of positive camber, what do I do
Don't worry about getting the camber links to exactly 32mm or whatever it is, you are going to adjust as necessary anyways.
