Tekno SCT410 Thread
![Default](https://www.rctech.net/forum/images/icons/icon1.gif)
Thanks for the tips! I had a pretty good grasp on the concept but still learned a few things. So for current limiter you basically only care about having enough acceleration for as much traction as you have, and Top speed isn't really effective since it's not pulling as much current at speed vs. hard acceleration hitting jumps going down straits etc. So if you punch it and are spinning all 4 wheels your just wasting power. Sound right?
Anyone have a good way of doing static weight distribution on this truck? I was thinking of making finding some camber or steering links I could replace the shocks with at the same length of the shocks when the truck is at normal ride height. then use the 4 scale method to set the weight balance. Just need to figure out how to replace the shock with a fixed rod, or lock up the shock somehow at a certain length. Maybe a shit load of o rings on the shaft?
Do take the tires/wheels off as they can be out of round and really wreck the scale readings. I use Legos to support the axles. Easy to make something that works out of Legos.
Using a solid shaft will give you the weight bias of the chassis. Or as the captain said below, any means to lock out suspension movement with equal f/r ride height.
Add shocks with springs to that and you are corner balancing the ride height adjustment.
You can not get an accurate read on chassis weight when you add that variable.
Example, get your baseline from all four scales, adjust the spring collar on one shock. The scales read different numbers but you did not add, remove or move weight at all on the chassis.
+1 on removing the tires, never thought about using legos, thats brilliant!
I'm going to be buying a 4x4 sct this month but trying to decide between the tekno and the ofna ts4 . I already got a rx8 gen2 a hitec 7955 tg and a tekin pro4 hd 4300kv . Iv read about the ofna and guys say its not great outdoors. I mostly run on big outdoor tracks big jumps dusty dry rough conditions . I hear the tekno is a bit on the heavy side . Can anyone give me some pointers on what's truley best for me
I drove Team C TS4 TE last season before switching to Tekno. IMHO Team C is lighter thus it accelerate quicker and jump higher. The problem is landing, awkward landing usually translate to DNF. With Tekno it feel more sluggish and harder to jump, but the car is more planted and stable and I can really push the car on my mains. I drive way faster and consistent with the tekno although I achieve best lap time with the Team C. The other thing is part quality with the Team C you have to change the plastic parts often whilst with Tekno, in 5 months I only change the steering block once.
Yea I figured the tekno was a tougher truck . Will the tekin pro 4 hd 4300 be a good motor for the tekno
Ok awesome another thing I like about the tekno is its a kit so I can know it front and back . The ofna is pre built
The Tekno is for sure the winner between those two. The only other trucks to consider would be the SCTE and Durango IMO. Just buy the Tekno, you wont regret it.
Awesome yea I have a couple of those turnigy 5.8 packs those should work I hope . Might
Pick me up some bigger ones
