Tekno SCT410 Thread
#9646
Cain- this is the srt410
we run 5 min quals and mains....capacity should not be a issue, testing will show the run time unless there are fortune tellers on this thread that know how long my 5600's will last
#9647
FWIW, I run a HVR 7k mah stick pack in a converted RC8.2 and I ran an 8 min main, with about a minute warm up, then after the race I let it cool down about 20 mins and let another guy finish the pack off, he got a little over 5 mins.
So, by that guess-timation I got 14 mins out of my pack.
Thats in a 7lb 10oz truck with a VIper VTX8 esc and RevTech 4800kv motor.
#9648
Is it the weight that's making you guys have such low run times I get 13 mins on a 4200mah nanotech shorty in my 5.6lb sc with a savox and 4600kv non sensored tenshock
#9649
Tekin Pro4 HD
Wow guys, pulled out the Pro4 4000kv and dropped in the 3000 Pro 4 HD on 3S. I was pretty hesitant to give it a try but the 540 is never going back in. Its able to clear jumps I had no hope of making before. Its awesome.
#9651
First time out with the new truck 3rd place.
Truck is great-HW4700 is a beast of a motor.'
I retract my statement that nosediving is a myth!!!!!! I am suffering from it as well now. I had to change my driving style to remain on the gas while jumping, otherwise I get a violent forward pitch that is usually unrecoverable.
I don;t understnad the cause as the EB48 doesn't do it at all.?!?! I tried springs, battery location etc. Still unsure about how to minimize it.
Can't say the same for E-buggy class this week though. What a hack fest...
It was actually worse then SCT this time around.
Chris I feel your pain wrt hacking. It seems like the track owners or announcers can do a better job with laying down some ground rules or protocol for hacking incidents.
#9653
This could also be an issue of a heavy trigger finger versus a lighter trigger finger? I have 6500 packs & after a 5 minute qualifier my packs take almost 3000 back in. I haven't run a 7 minute main yet but I don't think it would drain that much more mAh. I'm sure diff set ups, tires & traction play a huge part as well.
#9654
I just put a New Tekno 4300 HD in my truck today. Hooked up to a RX8. Its geared at 15t pinion stock spur. On the bench just running it for about 2 mins and on the road for 2 minutes my temps are 150+. It seems unusually hot for any motor to spike that fast. My settings are.
50% current limit
Lowest throttle profile on the RX8.
0 Drag Brake.
I'm actually afraid to put it down on the track... My pro 4 4600, was geared the same and same esc settings and temps barely hit 140..
Anyone else experience hi temps just bench testing? Plus it smells funny, could be that new burning smell, if thats even a thing..
50% current limit
0 Drag Brake.
#9655
50% current limit
0 Drag Brake.
50% current limit
0 Drag Brake.
#9656
50% current limit
0 Drag Brake.
50% current limit
0 Drag Brake.
#9659
50% current limit
0 Drag Brake.
50% current limit
0 Drag Brake.
Someone will chime in on gearing, sounds low but bench testing is bad for motors. Street is not a good comparison.
Take it to the track with correct gearing and you should see normal temps.
EDIT:
Just saw above ^
Noooo! Don't do a video of you running your motor up to 150° on the bench!
#9660
