Tekno SCT410 Thread
#5432
![Default](https://www.rctech.net/forum/images/icons/icon1.gif)
hey guys, those of you using the OFNA aluminum servo horn.. how did you put it on? the arm is low so the given screw from the kit will not travel the full distance.. it hits the servo as there is not enough space between the horn arm and servo. what are people using to traverse this issue? I see that people are using them but im stumped. I do have my moments btw, so help would be much appreciated. As I am relatively new to the hobby I dont have many if any spare screws laying around to try different options. Let me know thanks in advance!
#5433
What servo do y'all recommend for this truck.
#5434
Believe it or not I am using this servo with great success! Its actually the smoothest and one of the best I have ever used too.
http://www.hobbyking.com/hobbyking/s...dProduct=30909
![](http://www.hobbyking.com/hobbyking/store/catalog/HK47003DMG(2).jpg)
#5436
#5437
OK guys, after screwing around with my leaky shocks again tonight, I think I found the problem. The seal stack has almost no pressure applied to it by the lower cap. The o-rings have zero "squish" if you know what I mean. I put a 7x5x.25mm shim between the shock body and the first plastic spacer. Doing a vigorous hand pump (hehe) of the shock, I have no leakage now. I had immediate leakage before. Now the search for some x-rings begins....
#5439
XP-1015 great servo with my DX3S with NO cap works flawless...
![Nodding](https://www.rctech.net/forum/classic_images/smilies/nod.gif)
#5442
all this servo talk has me thinking. i may need to hunt me somthing new down..?
http://www.amainhobbies.com/product_...FQXpnAode3kAPg
#5445
![Big Grin](https://www.rctech.net/forum/classic_images/smilies/biggrin.gif)
XP has been in my Mugen conversion for 5 or 6 months and I run my saver really tight. No issues for me. Haven't broken a hitec myself either but I haven't run one in year and hitec kinda stunk back then. Way before HV was out.
I like the idea of running a HV servo on 7.4 but wanted to try the XP. May go HV later since my rx can take it. Don't feel like I need more holding power than what the XP has... but then again I haven't felt 400+ oz/in either
![EEK!](https://www.rctech.net/forum/classic_images/smilies/eek.gif)
![](http://i.qkme.me/pao.jpg)
