Tekno SCT410 Thread
#4876
Anyone running the the hobbywing 4700 . Looking for recommendation on esc settings
#4879
My truck is finally done:
light frame
carbon servo brace
RX8
Pro4 4600
nanotech 6600
losi hi-performance body
aka wheels and tires
no rear and center braces
total weight: 6lbs 12 oz
It will be hard to go 6lbs 4oz
light frame
carbon servo brace
RX8
Pro4 4600
nanotech 6600
#4880
What's the deal when turning the steering at full lock to either side, the inside wheel of either direction you turn sorta free floats a little more while the outside wheel is locked in the direction you have turned. The steering rod where it connects to the hub is where the extra play is. I've never had that in any vehicle I've built.
#4881
#4883
All you need to do is level the link from the servo to bell crank with a couple washers and a longer screw through the bell crank. I don't understand why that's so hard to figure out lol. I immediately noticed it and corrected it during the build before even powering on the servo.
#4884
I know this has been asked and I''m not sure where the hell it is.....Does Tekno plan on releasing aluminum carrier's, knuckle's, and rear hubs? I know that there really not needed but I would like to have them. I would also like to have them on my EB48 also.
#4885
Nah it's not the travel adjustment unless its not meant to turn to full lock and has nothing to do with servo, servo horn angle or servo saver it's in the steering turnbuckle where it's mounted on hub not the Ackerman. The inside wheel feels like it hits a pivot point and becomes very loose while outside wheel is fine and tight..
If its off and I turn by hand all way to right or left the outer wheel will be nice and tight and inner wheel you can move way too much. About 20mm of free play on inner wheel.
Now if I dial down the travel so it doesn't turn as far it can be removed but you'd lose a ton of steering and its not my first rodeo I'd say about 20 vehicles and I've never seen this
#4886
Hi, I know there were some of you runing at 702 Raceway for the Top Notch Series race last weekend. If you have the setup sheet, please post it here. I ordered my kit today.
#4889
Originally Posted by Foosmatrix
Tekno. any immediate plans to make aluminum spindles, spindle carriers, and rear hubs ?
No immediate plans.
Tekno RC
www.teknorc.com
Bummer. For now anyway
#4890
Hey bud what are you geared at and about how long is the straight on your track? Thinking of picking up a hw 4700 to have for a spare.
