Tekno SCT410 Thread
![Default](https://www.rctech.net/forum/images/icons/icon1.gif)
whats everyone running in the diffs for highbite clay indoor? Im running 7-7-5 right now but it pushes like crazy. Also, i went to try out the LRC rear brace and when installed i have a gap between the brace and the arms. Its about a 2mm gap that i can see hinge pin, are their different inserts or something needed to use the LRC brace?
Is something broken with the ones you have, or are you not wanting to run the vehicle with the parts you do have?
If the main concern is the shock caps, to be honest you should not let that stop you from running the vehicle.
Typically for more on power steering you would look to the diffs. A thicker front oil and/or thicker center oil would give you more on power steering. With out knowing more it's hard to say. where are the shocks on the top position? Stock is the pink fronts yellow rears? the stock setup steers pretty good. but typically it's the diff oil that will get you the on power steering that you are looking for.
I was thinking about going to a higher middle diff, like 10k, and leaving the front and rear stock. Maybe dropping the rear to 3k. Stock is what, 775? I may try out 773 first, and just rebuild my rear diff for testing this weekend. See how it reacts. I don't want to do a wholesale change and not know what effected what.
Going to a lighter rear diff oil will increase rear traction. If you are happy with the traction and drivability you currently have I would stick with 5 in the rear. If you want a tad more traction out back I suggest going down to 3 or even 2k in the rear.
Other guys can power right through the sweeper, and I have to really feather the throttle to get it to go through. Also have a hair pin just before the trips that I can't navigate quite right because of the push.
But with them hexs in the picture you only can use 1/8 buggy rims not 1/10 SC rims/tires right ?
No not correct actually. DE Racing makes a 17mm SCT sized wheel just for applications like this.
http://www.deracing.net/store/index....product_id=306
http://www.deracing.net/store/index....y&path=174_175
The first link the pic dint show up.
So you buy the Tekno 17mm hexs and still use SCT sized wheels and there just as wide and big as the 1/10 SCT wheels ?
Nah, I'm searching for more on power steering. She's pushing under power mid-exit of the corners. Just looking for options to try for practice on Saturday.
Hopefully the rumored Tekno setup guide thing is true and will be out soon.
Anyone ever tried the 17mm wheels on this or any other sct? When the talk of 17mm hexes and wheels first came up a while ago somebody mentioned that the offset of 17mm wheels is different than the 12mm wheels, meaning that a "0" offset 17mm is actually different that a "0" offset 12mm wheel, partly because the hubs on most vehicles using the 17mm are usually quite a bit bigger, ie 1/8 buggys and such. Just trying to make sure we have all angles covered here because I am very interested in making the switch for durability sake but will have to invest in all new wheels and tires since this is the only vehicle I am currently running
http://www.amain.com/de-racing-borre...93749?v=257253
