Tekno SCT410 Thread
![Default](https://www.rctech.net/forum/images/icons/icon1.gif)
Ok guys, now I am confused.
the truck I modeled this from has a 6 mm axle.
I know from past history that 5 mm axles are not strong enough on any of the
sct trucks.
Are you having troubles out of the 6 mm axles models?
And I really didn't now that we were going to get into a big issue with the retaining nut. We have been running this design on the Losi for a few years
now with no Issues that I am aware of.
but why not make everybody happy and put in the side retaining screw.
I have not anodized these as yet.
![](http://i270.photobucket.com/albums/jj86/m2cracing/tekno17mmhexnutsidemount.jpg)
Is this what everyone wants?
sct trucks.
If any area I could think of that they could have not "cheaped out", that's not one of them.
And to be honest, the only area I can thing of really would be the aluminum hexes. that's pretty much it for me.
I know of several guys running the plastic caps on the buggy and truggy actually...
![Nodding](https://www.rctech.net/forum/classic_images/smilies/nod.gif)
sct trucks.
sct trucks.
sct trucks.
sct trucks.
I have built many and still see guys racing them with plastic caps. Its a non issue with durability. Now if you want the bling ok then.
Do the Alum shock caps seal better than the Plastic caps ?
I wouldn't really say that. But they are nice to have, just incase you have just that right crash, and less chance of cross threading. IMO But I never seen a plastic one fail on my personal stuff or at my home track.
I'm going to be honest...your posts are very seldom positive. The plastic shock caps work absolutely fine on this thing. This is hands down the best 4x4 short course truck on the market IMO (and probably most others as well).
Except them 4mm axles that's quite a weak point over time
![Mad](https://www.rctech.net/forum/classic_images/smilies/mad.gif)
I have broken a plastic shock cap. It was a crash and not normal wear tear though. When the truck was first announced I was really hoping for a EB48 level spec with all the cool parts (at least at the time) and wouldn't have minded paying a little more for it as well. I too was a little disappointed at first, but I have no complaints with this truck. The plastic pieces have been durable (except the hexes and servo horn) and I have upgraded when parts broke or received as presents. Like others have said, the plastic shock caps are even desired by some.
I'll say it too, best truck on the market.
I need steering in my truck, can anyone point me in the right direction? Box stock setup, accept for rear shocks on outer hole in rear, and shock oils. Ride hieght at 27f/26r, droop 102/119. -1 degree camber on all corners.
Would a change to the rear hole on the ackerman bar give me more steering? Mostly on power steering is where I need help.
![Frown](https://www.rctech.net/forum/classic_images/smilies/frown.gif)
R/C Tech Elite Member
wow, you've made great progress Mitch, i'm glad you got the parts you needed to get this worked out so quickly. if given the option i would prefer them made from the eb48.2 axles as well. i understand that requiring people to buy the additional stubs over stock might be a turn off to some, but for others they can see the benefit of the stronger, more reliable axle.
in that second picture from 1/17/15 what would the track width with those be ? the hex looks a little wide.
whats everyone running in the diffs for highbite clay indoor? Im running 7-7-5 right now but it pushes like crazy. Also, i went to try out the LRC rear brace and when installed i have a gap between the brace and the arms. Its about a 2mm gap that i can see hinge pin, are their different inserts or something needed to use the LRC brace?
