Tekno SCT410 Thread
![Default](https://www.rctech.net/forum/images/icons/icon1.gif)
I think for a 2s setup the 2 shorter straps are plenty--I've been running my SCT 410 fine with them.
Couple weeks earlier I would of said the 2 shorter ones for the EB48 were fine too. That is until I broke both the shorter ones in a bad crash during a race. I finished the race & did not notice it til back in the pits. I actually broke both battery straps. The only thing holding my battery in place was the body.--Actually broke the rear body post too. I finished the weekend using the 1 longer strap. In reality you're probably fine using just the 2 shorter ones. I was for over a year til this one bad crash.---Funny I did not break any other part on the car. TEKNO DURABILITY!
Put some velcro on the battery tray and the bottom of the battery. Then 2 straps are more than plenty. I ran with two straps for a year in the Tekno SC.
A lot of it depends on the battery size. I run all three because my battery can still slide front to back in the tray if theres no long strap. Id rather take the extra 2 seconds and strap it in good than have my battery slamming around in the tray.
It really all depends on you, if you run different sizes of batteries, etc. I run three straps on the EB48 and 2 (side/side, not the front/back) on the SCT410.
![Laughing](https://www.rctech.net/forum/classic_images/smilies/laugh2.gif)
I was thinking of running one short and the long one. I might try it for practice, see what happens. probably leave all three for the EB.
Our tray is designed so that the straps are what is securing the battery to the car. That's not to say that running less than three straps won't work but we won't recommend it. And if you must run only two straps I would suggest one long and one short.
On some of our lightened trucks we cut the tray all the way down to a flat piece of plastic and never had any issues, but we were running 3 straps.
That's' what I've ran since I got it, one long, one short.
I only run the 2 short straps n my truck. Also to keep the battery from sliding I shoe gooed a piece of foam at the front of the battery tray to keep my battery from sliding front to back. Works great on my outdoor & indoor trucks.
One thing I am curious about that someone may be able to answer, I still have my Tekno setup with the 4 oring setup on the shock shafts as its an original SCT410, on those, can you use the 2 oring setup instead and should I compensate for this difference with sway rate increase? (running 2.3mm front, 2.2 rear right now)
Hey do you have your setup from the motodome? figure conditions there are in general very loose, maybe some stuff I can get from that.
Hey guys i just got a tekno sct410 and wanna know what setup you guys are using for outdoor clay tracks put how rough how much traction exc and get some ideas flowing on setup from stock like what shock pistons are you guys using for what condition track or shock or diff fluid what swaybars and so forth any help will be much appreciated
![Smilie](https://www.rctech.net/forum/classic_images/smilies/smile.gif)
Ok so I just rebuilt my car fresh diffs cleaned and oiled all the bearings I kept my shimming the same on the diffs from side to side now when I let off the throttle from the front diff area it sounds like it is clicking down but I don't get why I didn't change the shimming at all... Any ideas
And how's this for battery all the way back
![](http://i1163.photobucket.com/albums/q560/Blamey470/c6512444ed67e6536be98a53be1e8cbb_zpse03fcee7.jpg)
EDIT: It may be ok since it looks like your running the 540 can, but something to watch out for. Also if the post comes loose vs. the motor it will probably short out the ESC and burn it up.
