Tekno SCT410 Thread
Not a weird question. I started with the 3 wires already soldered to the ESC. Then I figured out how long each piece of loom needed to be and cut it. Next I stripped the 3 wires and tinned them. After the wires were cool enough, I slid the loom on and cut my shrink tube to the length I wanted. Slid the heat shrink tubing on over the loom and lined up the end of the shrink tubing to the end of the wire insulation and shrinked the tubing on. I let it set for a couple minutes and then soldered my wires to the motor. Really easy to do and makes the wiring look a little better.
Hope that helps ya!
[IMG][/IMG]
Hope that helps ya!
[IMG][/IMG]
Tech Legend
To me at least, I liked the HW motor enough (4000Kv version) that I sold the Tekins I had as I felt the power delivery and ease on the ESC was what I was looking for.
Mind you though, the Tekin 4300Kv HD is a beast so if you go that way you will still be happy.
As for escs to use in the Tekno. If you are looking for ESCs on the cheap, the Speed Passion GT2.0 Pro works quite well actually. I used that for awhile and my daughter uses it now until I switch her over to a VTX8, mainly as its water proof. But outside of that, its one heck of an esc.
Anyone running the PL evo sc body, if so how you like it overall, durability, flight, fitment on the tekno etc, I just picked one up to try out
You run at SDRC right? How has that setup worked out for you? Did it get rid of the push?
In my opinion, since the HW motor can take timing (the black can with the silver heat sinks around the middle) I think you can get the top end speed you need no prob if you ESC can do timing.
If you need more than the tenshock 4600. Then the hw 4700 will work great and it keeps up with the pro4hd real well. You just need a big track with that motor. I have used both.
Yup SDRC, I only race Saturdays and the parts didn't make it but there in so tomorrow I can try it out, last week I dropped to 27.5 ae oil in the rear with full rebound, 2 bumpstops and non vented bladder and the truck felt better, so tomorrow I'll throw in the 8x1.3s all around, green springs rear, drop front oil to ae 35 from 37.5 and also going to try 7/10/5 since I have to replace spur gear anyways, last week a small portion stripped but still drivable, looks like something got caught up in the mesh but I'll let you know how it goes
Tekno, have you thought about offering shock shaft bushings for upper eyelet to be sold individually so we won't have to buy a whole parts tree? And maybe made of a different material like delirium so they won't wear as fast. I'm starting to obtain a bunch of shock parts in my parts box due to buying the tree to just replace that top bushing. Just a thought, and I'm sure everyone would be stoked about it.
Nice tip, the OD fits nice & snug?
yes it fits nicely.
to drill the hole properly you need a lathe
We don't need no stinkin lathe
One Million!
+ 1 MILLION
+ 1 MILLION
But the HW is alot more cost effective. Not as ineffecient the HB will run longer on one battery.
But if your gonna get one motor and run 2s my suggestion is orion 160a esc and the 4300hd. This is the smoothest combo out there in my opinion.
But I can't say if it has more orque than the tenshock. Tenshock are amp hogs and grunt with the best of them. Most speedo companies don't recomend any tenshock motor, because of the amp draw.
