"How To Properly Build And Break In a Ball Differential and Slipper Clutch"
#407
![Default](https://www.rctech.net/forum/images/icons/icon1.gif)
associated ball diff, sc5m, 11 turns of screw to completely tight.
#408
![Smile](https://www.rctech.net/forum/images/icons/icon7.gif)
So helpful, thank you!
#409
This thrust kit is better than the MIP ones:
https://www.ebay.com/itm/Trinity-1-1...item2eff017d56
You may consider replacing the diff halves as well.
Out drives:
L & R.
https://www.ebay.com/itm/Associated-...item52186aee0b
I wear out the right one first!
Out drives:
L & R.
#410
Do you guys set your slipper the same way between buggy, ST, and SC? Seems like there should be a difference because of different lengths and weights of the vehicles.
I've always set my slipper by "feel." I'd set it it flush then drive around the track and adjust from there.
#411
Thanks for the videos. I believe its time I rebuild mine. I'm wondering however what does the truck do on track that tell you that its time for a rebuild?
#412
If rear traction is being WEIRD and inconsistent. (2WD)
Massive over steer for no reason.
If the differential feels CRUNCHY when you hold one rear wheel and turn the other.
It should be as smooth as glass with minimal crunchiness.
Gear diffs are what comes in a ready to rebuild car or truck.
They are minimal maintenance,but heavy. Ball diffs are race car stuff.
i have a few ready to go,when I need one for my OLD T-4.
I'm getting better at it.
#413
#415
I have a few more questions.
1. How can you tell if the diff is loose in the truck? I just rebuilt my diff and want to come in after a few laps putting around the track and check it. I'm just not sure how to tell without taking it back out. (I know how to tighten in the truck but dont want to unless its needed)
2. What will dirty/gritty thrust balls make the truck do on the track if anything?
3. Which side should the thrust nut be? Driver side or passenger? This is a Kyosho truck and the manual doesn't really show/say (at least Im not seeing it if it does).
**edit**
I've answered 1 and 3 myself by reading a document by losi on building a diff. Still would like to know how critical #2 is on the track.
**edit**
#416
![Thumbs up](https://www.rctech.net/forum/images/icons/icon14.gif)
Wish I found this video sooner. Great videos
thanks for taking the time to make them.
![Cool](https://www.rctech.net/forum/classic_images/smilies/cool.gif)
#417
thanks for making such efforts...it really seems helpful.
#418
Wow !! Nice description
#419
Location: 232/14 đường số 9, phường 9, G̣ Vấp, Hồ Chí Minh
#420
Wow, really thurrough and well made tutorials. Good to know that there is such a thing, I don't think I have a ball bearing, but just a cog diff.
