Like Tree5Likes
SC10 4x4 Thread
Old 01-14-2012, 05:08 AM
  #14836
Evil Genius jr.'s Avatar
Trader Rating: 28 (100%+)
Whats the difference between the front and rear driveshafts? I bent a rear one and replaced it with my spare front and it seems the same.
Evil Genius jr. is offline
Old 01-14-2012, 05:16 AM
  #14837
Trader Rating: 223 (100%+)
Mantis any links to your video's ?
Thanks for all the advice, your making me miss my sc10 4x4
Manatarms25 is offline
Old 01-14-2012, 06:58 AM
  #14838
wfdfiremedic's Avatar
Originally Posted by roylo
Hi. I have just purchased a new SC10 4x4 RTR. Should be arriving soon. Can anyone tell me as I cant tell from the pictures, is the receiver seperate to the speed control as I want to add my own receiver. Is it a straight forward plug in job?
Any other tips you can tell me for a new owner of one of these? Other than reading this WHOLE thread
Just fyi, you will probably want to turn your steering endpoints down, or play with your dual rate. The truck has a massive amount of steering stock. I am probably running like 65% on my endpoints and have plenty of steering.
wfdfiremedic is offline
Old 01-14-2012, 07:06 AM
  #14839
Old 01-14-2012, 07:18 AM
  #14840
symmetricon's Avatar
Trader Rating: 27 (100%+)
Originally Posted by Evil Genius jr.
OUCH!! You must have blasted into something real hard.
symmetricon is offline
Old 01-14-2012, 07:19 AM
  #14841
Yeah, I don't know when it happened though. A rear dog bone was also bent.
Old 01-14-2012, 07:24 AM
  #14842
^^ No good! LOL
Old 01-14-2012, 07:35 AM
  #14843
skengines's Avatar
Trader Rating: 226 (100%+)
Ran my sc10 4x4 with the clutch basket and garodiscs. I stripped an idler gear..is this because I had the slipper cranked down too much?
skengines is offline
Old 01-14-2012, 07:37 AM
  #14844
Mizchief's Avatar
Congrats! breaking this truck takes some real doing. I've tried and failed on several occasions.
Mizchief is offline
  #14845
sugs's Avatar
Rear driveshaft is 1-2mm longer than the front(eyeball, didn't measure). Possibly could pop out at full compression using a front on the rear. You can fully compress that side and look to see if its close to coming out or not. Might be OK.
sugs is offline
Old 01-14-2012, 09:15 AM
  #14846
SCIDA's Avatar
Originally Posted by Mizchief
Thanks for the info! The more I learn the more I find out there is to learn. Overall I like the handling much better than I did before the center diff and dual stages.
I could push the big 90deg sweeper as hard as the tires could grip without traction rolling like I was before, it would go right into the perfect drift angle instead and with too much speed would drift to the wall gradually rather than roll or spin around.
While most of the other guys were more green than I running 2wd's it still felt great being the fastest guy out there and I got a lot of practice pacing the other cars from a few feet behind watching out for an avoiding them when they wrecked and trying out different passing lines.
I think your right about the rear traction, while the fronts would ballon, it was only at near full throttle with the 4k pro4 and the rears were laying some rubber in the process. I guess I can't ask for much more than having all 4 wheels spin at the same time.
I'm think saddle packs may be the missing ingredient in this, having that weight riding a little closer to the front should help keep it more distributed.
Have you tried running overdrive? Meaning run the 19t front pulley?
SCIDA is offline
Old 01-14-2012, 09:22 AM
  #14847
SCTDan's Avatar
I don't think overdrive is recommended with the center diff
SCTDan is offline
Old 01-14-2012, 12:04 PM
  #14848
Thomas P's Avatar
Yes it is.
Im running that basket with my 4600 550 castle 4 pole on 58/19T gearing indoor with tiresauce..meaning sick good grip...this slipper, working flawless...and easy to adjust..
app, one foot of slip, o little less on real good grip
Thomas P is offline
Old 01-14-2012, 05:19 PM
  #14849
johnbugman's Avatar
Default Ya I said so!!
coyote slash is a moron!!! He is always piggybacking mantis on this forum and now he has the nerve to start schooling people on here like he knows something about some complete strangers product and how its best used!! Typical know it all!! Good luck jack of all nothing!!
johnbugman is offline
Old 01-14-2012, 05:29 PM
  #14850
jsamarin's Avatar
has anyone tryed the trakpower 5400 60c saddles? They seem like a good quality pack. Id perfer an orion, but up here in canadia, high capacity/high C batterys are hard to get.
jsamarin is offline
