SC10 4x4 Thread
![Default](https://www.rctech.net/forum/images/icons/icon1.gif)
Lemme start by saying I HAVE searched, and older posts and conflicting opinions still have me confused. It's about the Castle SCT 1410 combo. Looks like some people have run the Sidewinder and been fine, some run a cooling fan, some mount on the rear shock tower and cut holes in the body for cooling. I could run it, or put it in my 2wd SC10. I have two options for the 4x4, I can run the Castle 1410 with a Tekin RS Pro that I own, or just purchase a MMP and run that. What is my best plan of attack here? Will the RS Pro be ok with the 1410?
Just get a MMPro if you are on a budget or get an RX8 or the other 8th scale controllers to be safe.
4x4 SCT is closer to 8th scale in terms of stress on equipment/electronics so you are much better off using higher spec'd equipment.
so, i bought this truck used from a friend i race with, and since i got it i have put a mmp in it, a x12l lrp motor, new belt, stiffer sways, team orion servo, bec, all the bells n whistles, bt my question is this, and please dont think me dumb b/c prior all i ran was 48p pinion/spur.. is a 32p pinion/spur supposed to b very loud> i mean my 48p setups are nearly silent, however this 32p is extremely loud...
it is a little louder but not as loud as it would be compared to a mod1 mesh. make sure your mesh is adequate and not too tight.
Trader Rating: 77 (100%+)
question...I am considering the Exotek chassis. I have 2 SC10 4X4's 1 for me and 1 for my son. I have already invested in eight 2S lipo stick packs. Would it be worth it to run the standard battery setup with the exotek chassis or is it that much better running the saddle pack set up? I run on a med/low traction track. We just club race, not really a big deal. Just wondering.
Saddle packs do help balance the truck out, but you can add weight to do the same. I would like to use saddles but I can afford to buy new batteries and the b44 pack kit. I can weight my truck for 10 bucks and get the same result, as a saddle conversion.
Tekin has stated in other threads not to use the RS speedos with 4x4 short course. Will it work? Yes, but it isn't nearly as robust and will always be on the edge of blowing it up.
Why is that? I would much rather know much current the motor and gear combo are going to pull, then pick my esc and batteries based on that requirement.
Thanks, probably just get the MMP, sell the Sidewinder, and put the RS Pro into my 2wd.
The tranny outdrive wobbling problem is the only remaining issue for me with this truck. I notice the wobbles after only a few pks with the new rear tranny case and it got so bad by the end of day the internal gears inside the tranny would skip under hard acceleration.
Using double shims and wobbling seems to go away...for now.
Something I've noticed when I got involved with land R/C after a couple years doing air, is that no one ever talks about the actual amps being used. When you buy an Air ESC it almost always says right in the name "80A ESC" etc. where in land it's always talked about in terms of scale or "higher spec'd"
take a dremel and remove the arm material until it clears your out drive, also you can limit the up travel by putting shims on the shock shaft just above the spring cup
Almost done with the set-up ..
Its Cody's.....![Spiderman](https://www.rctech.net/forum/classic_images/smilies/spidey.gif)
Rear details....
1.8m sway bar
7k diff oil
20T pulley
rear shock
emulsion shock
yellow spring
30w
1.2m piston
no limiters
1m rebound
Shock position
inside on tower
inside on arm
camber link
middle hole on rear hub
inside on chassis, no shim or washers
ride height 24m, ft & back
comments
full time 4w drive
chassis brace
Saddle Packs mounted inline , 1oz behind battery,1oz back wall of chassis under belt, 1/4 oz back corner by gear cover, standard decouple slipper
Its Cody's.....
Rear details....
1.8m sway bar
7k diff oil
20T pulley
rear shock
emulsion shock
yellow spring
30w
1.2m piston
no limiters
1m rebound
Shock position
inside on tower
inside on arm
camber link
comments
full time 4w drive
chassis brace
Parts you need for saddle pack installation
B44.1
Straps #9786
Tray #9775
Posts #9745
Screws # 6292
countersunk washers (blue) #89229
Started on the set-up , its Codys !!!![Spiderman](https://www.rctech.net/forum/classic_images/smilies/spidey.gif)
Finish the ft end today ......![Rotating Tire](https://www.rctech.net/forum/classic_images/smilies/tire.gif)
details
no over drive
10K diff
white sway bar
emulsion shock
yellow spring
32.5w oil
1.2 piston
no internal limiters
no external limiters
+2 turns on shock eyelet
2m rebound
shock position
inside on tower
outside on arm
ball stud outside on tower , 1m shim under stud
B44.1
Straps #9786
Tray #9775
Posts #9745
Screws # 6292
details
no over drive
10K diff
white sway bar
emulsion shock
yellow spring
32.5w oil
1.2 piston
2m rebound
shock position
inside on tower
outside on arm
first half of set-up
