SC10 4x4 Thread
so who all is running saddle in the Exotek chassis?
Hey jeff, im running them, modified b44.1 set up to work in it though, i didnt like how exoteck did there saddle pack setup that there selling, truck is ridiculously good now on large 1/8 scale track, cant wait to get ball diff from marcus though, i think thats gonna be the final piece
did you have to balance it afterward? Where do you run? Got any vids?
Seems perfectly balanced to me, iv been running out at lake park lately, nothing there can touch it, been giving nitro buggys the red ass out there
what do I need to do to make the stock chassis to a saddle pack conversion?
I'll have to check that place out sometime. You should come out and run at Titusville/RCIS/OutaControl sometime. We need more AE's to represent.
I will be back in tampa for christmas, let me know when you guys run out there, il def check it out, il let u try out my truck when i go, u will absolutly be amazed at how easy it is to drive fast, i also got 4 pole 5250kv tenshock motor last week, u thought that tekin was fast?? Lol
that's cool, when a truck is easy to drive and having no issues, you can just concentrate on driving than worry about anything else.
I can't imagine driving on a track with that size motor LOL
Yea that motor sucks down 5500 mah in 7 min!!!!!
The alumium screws can actually be used to remove weight high in the truck and then add more ballast low. I have used the aluminum screws in everything that is above the chassis line. The bottom stays all steel. This will help lower the CG, a little. Everything helps though.
I agree there are areas that are more important to spend money on first, but after your done with the big things you can move on to the smaller areas. Plus I like the way they look.
some great advise from the 'Team"
suggest you first go to rc10.com and check out some of the set-ups available for the Sc10 4x4 ...
When you start , fill the diff's with oil , check the shocks
over & tap off with oil .
Use the 19T overdrive up ft & the 20t for rear....
7000w ft diff oil
5000w rear diff oil
7000w ft diff oil
5000w rear diff oil
How many of ya'll are running the Exotech center chassis piece?
