SC10 4x4 Thread
i had a similar sound and it did it until it broke the belt in half!! after inspection the rear pulley was getting worn, you really couldnt tell until i took it off.
the bushings are the culprit, they need to be made of steel instead of soft bronze, the oring is just a seal.
I was thinking about buying the hot racing diffs but some people posted a while back that they where junk. I dont see how anything can be worse than the stock diffs.
Was checking the exotek site today and I happened to see he new alloy chassis that adds 5oz. to the chassis, thus adding a bit mor steering. Has anyone tested this? Is it worth the $110?
http://www.exotekracing.com/new-lcg-...e-ae-sc10-4x4/
That's the one thing I never tried was the overdrive pulley.
Here is the A-main of round 1 of the Rockstar Short Course Series. We have a spec tire of the AKA Rebar's (first time running on them). I got to the track 15min before qualifying started so I did not get any dial in time besides my two qual runs. I decided to try the pin mod again in the main (this video) with a 20t front pulley. I had be running the MTK slipper with 19t front pulley. Rebars seem to slide around to me off power but everyone has to run them so I will get dialed in by the next round. The Losi truck that TQ'd is a factory driver and is I always on his game so I was not going beat him showing up late. We where the only trucks to turn 19 laps and run 15.9 lap times. I lost about 8 seconds on a turn marshal (lower left off camera) and another truck jumping the track that pretty much decided that I was not going to put together a good run to keep up with the Losi. Still always fun and always learning more of what I like and don't like.
+ YouTube Video | |
I am the orange and white truck qualified 2nd.
It was also about 1am in the morning when we ran our main.
I run a 540, 6.5 turn motor also. My track might be slightly bigger. I don't think I could handle a 550. I run about 135°-140° after a 6 minute main. The 1st place guy (black truck) is a factory AE driver running a 540 also. He comes off at 180°-190°with his LRP. I'm in 2nd with the white and green truck.
+ YouTube Video | |
This was/is the track I was mostly running at. I can't find a video of the 4w class, this one is 2w and supposed to be 17.5 no timing, but I'll be damned if I'm the only one who doesn't have a 13.5 or more. 540's here are no bueno. No, this isn't my video, and yes I am in it, and yes I won.
Anyway, this is the smallest track I run on. It is a sandy clay loam, hard packed with a loose top layer AND it will start to break up if it gets watered wrong. And it will thermal a 6.5 540 in six minutes geared 62/13 with no timing. Sucks because I think it would be faster because it's easier to drive than the 550 given the traction, IF I could get over the heating issues.
+ YouTube Video | |
The track you ran on was way more open than my track.
I can't seem to get into PRCR. I don't know... It feels like a dungeon in there. The friendly atmosphere is just none-existent. I also enjoy more forgiving tracks. That track is vicious. I dunno. Guess i'm fickle.
So the solution is to replace ASC 91005? I could see how if you got a lot of lash in those bushings it would change the mesh on the countergear and bust it, which might explain that issue...
I despise racing indoor for this exact reason. Sooner or later, everyone there starts acting like BF Skinner's rats, in some perverse real life behavioral experiment. Not the scene you are looking for if you are racing to relax.
At least it's better than a 30 dollar Alum diff. (for now)
Edit: Just got it all back together. It feels identical to how it was before (that stiffness I was talking about is gone) and it eliminated almost 75% of the wobble. It's back to how it felt stock. I'm happy with it. I have brand new diffs in my toolbox but I don't want to use them without a 'real' break. (I'm cheap)
I added another stock shim under the sun gear on both sides, no more wobble and feels smooth. Hope it holds up.
