SC10 4x4 Thread
#8716
![Default](https://www.rctech.net/forum/images/icons/icon1.gif)
Will do! Thank you for taking a look.
#8717
Guys, just wanted to say thanks for all this info, been reading this thread for a few months, even before my truck got here, pretty much done all the mods, just did the pin, like you guys say, it's a new truck, can't wait to get a weekend off so I can race it again! Big ups guys.
![Nodding](https://www.rctech.net/forum/classic_images/smilies/nod.gif)
#8719
I disagree with the second part, low bite is where this mod works best.
I agree with the third part, users should test their own stuff and not rely on me or any other random person on the internet. Worth every penny you paid for it!
#8721
![Rotating Tire](https://www.rctech.net/forum/classic_images/smilies/tire.gif)
#8722
Taken from a set-up guide in reference to the center diff on a 1/8 scale type drive train. (like Losi and Durango) Just think of it as Thinner being standard and Pinned being Thicker.
Thinner
• Front wheels unload more during acceleration
• Decreases on-power steering (reduces oversteer)
• Easier to drive on rough tracks
• More off-power steering
Thicker
• More all-wheel drive effect
• Better acceleration
• Increases on-power steering (reduces understeer)
• Better suited on high-bite, smooth tracks
• Car can be more nervous to drive especially if a high
power engine is used - you might need to be smooth on
the throttle
Thinner
Thicker
the throttle
#8723
Thinner
Thicker
the throttle
Thinner
Thicker
the throttle
![Sweating](https://www.rctech.net/forum/classic_images/smilies/sweat.gif)
#8724
We evolved "communication" to find things out faster as a network. It's human nature to ask for another's opinion based off their experiences. I am/was only asking "after" this mod, if you guys had to switch up anything immediately to get the truck to cut a little better like 'before'. I was 'not' asking for someone to tell me how to tune my truck so it's "gud 4 rac'n man".
Yesterday, another user implied I thought he was an idiot because I recognized right off he hadn't seen a slipper basket up close. In fact, the opposite was true - I knew he was a smart guy, and I knew he didn't understand it precisely because I recognized he hadn't seen it.
If you are asking me what I would do if I thought the truck needed to cut harder - I'm inclined to suggest unlocking the front clicker. It would be easy to undo if you hate it. I cannot tell you if it works or not because I haven't tried it yet.
#8725
There is always other factors that can make what it should do and really does not be true. Dusty conditions like in the video will give lots of tire slip. Your going to get on power steering and like the 4w lock up to drift and pull the truck around and out of the corner. The belt is also going to have some give as you go from on and off power and running through rough sections.
#8726
Thicker
the throttle
The last one (you can totally beat on the throttle with the belt pinned) disagrees with the first one and second one (AWD and better acceleration), but it doesn't increase on power steering IMO (you could pivot the truck with the throttle decoupled, users like Mantis are complaining about the truck not rotating center off compared to before), I'm ambivalent on the fourth one.
I would be inclined to think decoupling the slipper would work well on a high bite and smooth track. My experience in a low bite and bumpy track was that the weight stayed transferred to the rear tires, and they stayed loaded - right up to the point where you hit a bump and it would get sideways on you.
#8727
What I know is:
Unpinned:
Entering the Corner: Good
Exiting the Corner: Bad
Pinned:
Entering the Corner: Bad
Exiting the Corner: Good
Very Generic and very unspecific, Point is as far as driving, I can't mess up a corner entrance (too badly) but I sure can mess up the exit.
I have to say I noticed more powering through bumps, falling off ledges, I just powered through. The gain of power from this truck may be clouding the actual judgement of how it's really handling the bumpy rough track having that 550 in it. It I was to calm down and drive the line I drove before, I would bet that Craig would be correct in it not doing as well as unpinned, letting things slip, grip go where it's needed, etc. Compared to locked up and go is go.
No?
Edit: This is "myself" attempting to drive the same way I was before this truck was Pinned. It's going to take me a couple more packs to get a "good/good" which I'm sure I can get. these were just immediate changes in the performance of the Truck from My Experience with the modification.
Unpinned:
Pinned:
No?
#8728
Well everything can be made to work. The top drivers at Nationals the Losi guys use 5/7/3 and the Durango guys run 30/50/10 on the same track with the same tires. It is what works with the rest of the truck.
With the pin in maybe lighter front would be the best at a track or heaver rear might work too. We just need to figure out what works best with this truck.
On a side note STRC needs to change their steering racks to give us another hole back on the rack. Beat AE to the public and your going to sell some steering racks.
![sneaky](https://www.rctech.net/forum/classic_images/smilies/sneaky.gif)
#8729
It's just different now - and its all little stuff I would do to get the car to rotate or pivot or even jump before the pin doesn't work.
The track I ran on today is really an 1/8 scale track. They have an enormous set of triples in the back stretch that unpinned I bet I crashed over 1/3 of the time. The truck really rewards smoothly rolling up on the power by having a better in air attitude where before you had to NAIL IT right out of the corner to jump the darn thing and it would carry the front bumper at a 45 degree angle. I blamed the body, now I can jump anything with minimal drama.
Seems to me the truck can be driven more aggressively with the pin, but it still rewards a driver with a smoother style.
#8730
