SC10 4x4 Thread
#7756
![Default](https://www.rctech.net/forum/images/icons/icon1.gif)
The codes are for gold members, they will only work for the person tower sends them to........ I get them every now and then as well........... But I've been shopping at tower for almost 5yrs.......... The more you spend if your a super saver discount member the higher your status goes.........
#7759
#7761
![Smilie](https://www.rctech.net/forum/classic_images/smilies/smile.gif)
#7762
I moved my battery to the center line so left and right weights are the same with a rear weight bias. Really works well for me. I also tried 37.5wt oil front and rear with the 2 stage pistons. Our track is tight blue groove with no big jumps and heavier oil keeps it so planted it's crazy. Cut 1.5 - 2 sec off my lap times for a 25-30 sec lap track.
#7763
i just changed the diff oils to 5k rear, 30k front, 1.5m rear sway bar, 2m sway bar front, loosen the belt little.
ITS SHAKING HARD and can't find the cause. can someone help with this shaking?
thanks
RC
http://youtu.be/b4XeYBpzU6c
thanks
RC
#7765
![](https://www.rctech.net/forum/rctechv3/special/techelite_alt1.gif)
Location: Norwood, OH...and CCRCR and The OhioRCFactory
Those tires appear to be very flat-spotted.
#7767
thanks
RC
thanks
RC
#7768
finished the build of my truck today. Builds nicley. But a few questions. The servo saver on the very top seems to be rubbing a little. Second, the drive train seems kind of tight. porb will free up when I get to run it. Third, I put a 1015 xp for the servo. The wire isnt long enough to reach the radio box? Would have thought they would have designed the truck around there own servos? I know I can get a extension but Im mean come on its like 2 inches to short. No pun intended lol.
#7769
#7770
hey rchoi ,
when storing your truck pull the tires off or better yet keep it elevalted on a stand with tires off. This will prevent the flat spot out of balance tire shake that you have in the vidieo.This also slows down the eventual bowing of the arms also.
