SC10 4x4 Thread
#7443
Evening guys,
so Ive had my sc10 4x4 for about 3 weeks now, testing and tuning.
Here is what Ive done so far.
Just doesn't feel as planted as it should, well as a losi. Can anyone give me some setup advice on what to try out? thanks everyone!!
#7446
Thank you for the suggestions! I'm gonna try that all out asap! What would you try first the springs or shock oil change? or both at the same time? Thanks again!
#7448
#7449
I tried the middle whole and started to traction roll again....didn't like it so went back.... as for the wheelbase adjustment I'm actually unsure on how to do that. Getting into the manual now to try and find out. Thank you for the help!!!
#7453
#7455
R/C Tech Elite Member
Hey everyone, been searching on this thread for a few days now and haven't found an answer to an issue I've been having, I don't know a lot about tuning, etc so I figured I'd ask on here and maybe get an answer or some suggestions on what to try... the track is just a small backyard dirt track, mostly dry and loose/dusty, the issue I'm having is the rear of the truck constantly wants to spinout, it doesn't matter if it's on a corner, straight away or start, the rear just wants to come around.
My SC10 4x4 has 5000wt diff oil f/r, high torque slipper pad, slipper tightened, 30wt front, 25wt rear, rest basically stock.. running an rx8 w/ a sc4x 5.5, gearing is 15/62, temps only about 110-120, running snipers all around and tried calibers all around, along with mixing/matching them etc..
So far I've tried swaybars, different springs, overdrive front gear, etc.. I know I can go up on pinion but going faster just makes this worse so I was hoping to fix the issue before trying to go faster, and I am hoping to try a thicker diff oil in the front next week but 5k is the highest I have on hand.
Soo yeah.. if anyone has any ideas, suggestions or anything about why the rear wants to come around it'd be greatly appreciated.
