SC10 4x4 Thread
#7216
Trader Rating: 77 (100%+)
![Default](https://www.rctech.net/forum/images/icons/icon1.gif)
I tried a Viper 540 6.5 geared 17/93 on an outdoor track that is about 115x65. The motor was brand new never even saw a practice lap. I was on a tq run and at about 4 min 15 seconds that motor melted down. It was around 200 when I temped it. My friend was also running a 540 7.5 in his coming off around 200 every run so why does the lrp keep in truckin but the viper puked on its 1st pack? This has made me scared to try another 540. The motor ran awesome for the 4 minutes it did run. It had more grunt and top end then the sc4x 5.5 I was running previous. I would like to give the 540 another chance but I do not want to smoke another motor. I already have a NEW Tekin 540 6.5
#7217
Agree , Lrp 550 runs around 190+ , yet their "rip" is superior to any other 550 I have tried ....
Tip: switch off coast brake when using above ...
#7220
...or the Robinson Racing 32 pitch pinions. I have both Traxxas and RR pinions and I like the RR better.
#7221
17/93 is pretty tall for a 540 motor. I do have the fan mod done so that helps with temps but I normally run around 14/93. -5 on the motor and no timing in the speed control.
One thing I heard using the Tekin RSpro is that if you are in sensor mode and have it at zero the speed control still has 15 deg of timing added. Something about the speed control using the sensor can see the rotor coming. You have to be in blinky mode or duel mode for zero timing. I notice my motor ran hotter in sensor mode. Not sure if other brands have this problem too.
![crying](https://www.rctech.net/forum/classic_images/smilies/bawling.gif)
http://www.teamassociated.com/pdf/ca...ut_Wachter.pdf
Cav and Numedahl both run 5.5's and have their gearing listed as 16/93... I guess AE team guys can afford to run overgeared or they have special motors or torque rotors and don't mention it on their setup sheets.
#7222
Hey man, I run lrp 550's in my truck and they come off at 210-220 consistantly. I talked to maifield who showed up at comp hobbies friday night and he said thats normall for our motors. Lrp's run a little hotter than the rest and he said its no problem, its just in there design.
both times the truck was in top shape and driven by one of holland's top drivers.
based on good experiances with the speed passion silver arrows V1.0 I just orderd the silver arrow v2.0 5.5 turns and Im returning my brand new X12L 5.5
bad luck or bad karma or bad batch I dont know, but as you might guess, I have little faith in the X12L 5.5
but happy for you guys its running ok
#7225
#7227
#7228
I dont know how but I have seen 2 brand new LRP's X12L 5.5 turns motors go dead in this truck.
#7230
