SC10 4x4 Thread
#7142
![Default](https://www.rctech.net/forum/images/icons/icon1.gif)
I hate deans ultra.
BUT I love your routing skills, so that's great stuff you have there
![Wink](https://www.rctech.net/forum/classic_images/smilies/wink.gif)
#7143
OK here it is; a little under a month in the making.
We tried several different configurations of saddle packs and found no real success in handling for most all racer levels. Plus the fact that owners of SC trucks (and most electric guys in general) don't have saddle packs.
I'll let the pictures do the talking:
Edit: I forgot to mention, there is "0" lead or balance weights anywhere.... and the battery is in the mid position.
#7144
![Exclamation](https://www.rctech.net/forum/images/icons/icon4.gif)
Hoping someone can post the Lipo battery and ESC area dimensions (LxWxH -stock config) in mm on the SC10 4x4 whenever possible. Need to know if the lipo hardcase and 1/8 ESC I just purchased will fit.
Thanks for the quick response.
![Smilie](https://www.rctech.net/forum/classic_images/smilies/smile.gif)
#7145
Not at home so can't measure the esc, but the lipo's I use (Gens Ace) dimensions are:
138 * 46.5 * 25mm
Now with the foam pads on each end its a pretty tight fit, without the pads the longest I'd say you can go is 142-144mm , the width is pretty tight but a 48mm would be pushing it and the height maybe 26-28mm at the most. These are just guess's so don't quote me on it. But the dimensions I posted of the gens ace fit really snug............
138 * 46.5 * 25mm
#7146
#7147
I won't get to race it until next Sunday, but running it up and down the street it feels great. My 1410 setup pulled wheelies, but this thing damn near rides one out.
![Laughing](https://www.rctech.net/forum/classic_images/smilies/laugh2.gif)
#7149
Yeah, 4600kv. I installed the fan because I use the underbody chassis cover.
I installed a 14t pinion and will adjust from there come race day.
#7152
Battery and ESC Area Dimensions
Thank you.
Anyone else who can provide info as well.
138 * 46.5 * 25mm
138 * 46.5 * 25mm
![Big Grin](https://www.rctech.net/forum/classic_images/smilies/biggrin.gif)
#7153
I currently run IP LiPos, they slide in pretty hard, 27mm high. You could probably fit up to 30-32mm in there, with some force involved to fit the battery.
Other than that, dimensions are:
145mm long, 50mm wide for the battery tray.
With RX box installed, ESC/Transponder tray is:
105mm long and 50mm wide.
#7154
Don't have the truck yet and was in the process of first getting the electronics needed when I do.
Hope I can make the battery fit.
#7155
38mm... That is too high indeed, you'll need to modify the chassis brace (aka dremel it down) to fit the pack... I've tried my best, and I can't fit more than 32mm in there. The battery hits the belt cover :/
Another option is remove the cover, fit the battery, put on the cover, and charge the pack with it mounted on the car.
Don't bother with the battery holding strap.
With the foams properly installed the battery locks itself on the slot, needing no additional support. I don't even run the strap locker.
